Philips 37PFL4606 No Power
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 37PFL4606 No Power
    The 9.8V is just too low and I can't see why. The +5V SB is working so IC905 must be working. Can you measure the voltage across ZD908 and test capacitor C946
    • trunks81
      • May 2020
      • 265
      • Nederland
      Hello
      The voltage across ZD908 is 7V, and the cap C946 measure in circuit 48uf and also outside of it.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        ZD908 is an 18V zener so with voltage across it appears to be OK.
        Can you measure R959. Using meter in diode mode check across D916 in both directions.
        Just out of curiosity can you also measure the resistance between the 12V supply pin and chassis and also the 24V pin and chassis of the connector.
        • trunks81
          • May 2020
          • 265
          • Nederland
          R959 is 4,7ohm both ways,
          D916 is working measure 0.5V and reverse OL
          12V to ground is 1Kohm
          24V to ground is 2.4Kohm
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            There doesn't appear to be an issue on the secondary side of the 12V and 24V supply.
            R959 and D916 check out OK.
            Need to think about what else could be causing the problem but I'm fairly sure the 9.8V is the issue.
              What Voltage do you have when measure at the two legs of the cap C946 when 1K resistor is in place and not in place?
              • trunks81
                • May 2020
                • 265
                • Nederland
                #27
                When in place iam getting 9.8V and removed 8.1V
                  OK, check the resistance between the two legs of C946 and C922, the meter should show very low resistance at the beginning then it should be in K Ohms range after 10 seconds or so.
                  Also check the resistance between the positive leg of C946 and C922 in both directions of the probes.
                  • trunks81
                    • May 2020
                    • 265
                    • Nederland
                    #29
                    Hello
                    I do not see that the resistance is low in the beginning
                    C946 = 7.14Kohm, and reverse 56.2Mohm
                    C922 = 8.2kohm, and reverse 104kohm
                    Between the positive legs of C946 and C922 51Mohm and reverse 12kohm
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      • trunks81
                        • May 2020
                        • 265
                        • Nederland
                        #31
                        What do you mean ?
                        • trunks81
                          • May 2020
                          • 265
                          • Nederland
                          #32
                          C920 measure 8kohm and reverse 100kohm
                          • trunks81
                            • May 2020
                            • 265
                            • Nederland
                            #33
                            ive have an other board from an 47 inch model.. which has an short in it so the fuse keeps blowing C920 and C915,C922 all measure 270ohm
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              It would be better to post this as a new thread otherwise it will become confusing.
                              • trunks81
                                • May 2020
                                • 265
                                • Nederland
                                #35
                                oke sorry.. any other ideas to get this one running?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  At the moment I don't but others may well step in to assist.
                                  • trunks81
                                    • May 2020
                                    • 265
                                    • Nederland
                                    #37
                                    Tommorrow i have an working power supply, Hopefully we can reverse engineer it back ti the fault in the other one's
                                      Hello
                                      OK, they look OK, I was looking to see why you only getting 9V, I need to look further in the circuit.
                                        Hello
                                        Between the legs of C907 iam getting 309VDC,
                                        Edit is allready replaced D901,Q902 and R919 because board whas doing notting in the begining
                                        I need clarification about this.
                                        Did you have 5V Standby before replacing those part in the PFC circuit? Were those parts bad?
                                        • trunks81
                                          • May 2020
                                          • 265
                                          • Nederland
                                          #40
                                          Those parts were bad. so needed to replace them.. did not measure 5V because fuse kept blowing.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
