SAMSUNG LED TV UE46B6000 problem
  • anno
    • Sep 2007
    • 140
    • netherlands
    Hi
    i have SAMSUNG LED TV UE46B6000 tv. the relais are clicking.
    i found out, it start then go into shutdown.
    power supply is BN44-00269A
    i found a shorted FET (Q9103) , in the led driver section of power supply.
    i replaced the FET, the Tv started up and worked short . The image was dark so i increased the brightness in menu. Then the tv shut down and same FET was shorted again. how is this possible
    I checked the components near the FET and they are OK.
    maybe its a bad driver chip? or backlight are using to much current? i thought it has protection when that is?
    anyone can help
  • Diah
    • Feb 2013
    • 6399
    Re: SAMSUNG LED TV UE46B6000 problem
    bad FET i guess
      • 12206
      • U.S.
      Could be, have to be careful where you get your parts, don't know where you got it but some of those chinese sellers are selling junk.
        You have 6 boost converter circuits for six LED strings, Q9103 is one of six boot converter, it is possible that you have have some shorted out LED in that string. There is CS pin 5 of LED driver IC to detect over current condition to shutdown the drive to the MOSFET, but it may not be fast enough.
        Do you have LED tester to test the Vf of each one of the LED string?
        Like other said, it may be bad replacement MOSFET too.
        • anno
          • Sep 2007
          • 140
          • netherlands
          Thanks for the info, i got the FETS from ebay (uk seller) . no idea if they are fake or not?
          Can i test the LED Strings with adjustable power suplly? i have to limit the current?
          can you explain that a little bit more?
          if its not possible can you recommend a good led tester? or tester from china (aliexpress) is fine too?
          • anno
            • Sep 2007
            • 140
            • netherlands
            I have bought a led tester. How can i test the led strips of this tv?
            wich wires ?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4367
              • Italy - Milan
              A basic substitution.for suspected half broken components includes D9102, C9114, R9114.
                which wires ?
                https://www.badcaps.net/forum/attach...2&d=1596832161
                Notes: You may have to probe the connector from the wire entrance side of the female LED connector.
                If you are going to probe from the front side where the female terminals are, you must be careful not to expand the female terminals otherwise they will not make good contact withe male pins header.
                Look at the female LED connector that goes to male connector CN9401( Notes: do not plug the female LED connector to the board)
                LED string #1
                Pin 1 (Blue) = Red probe
                Pin 3 (White) = Black probe
                LED string #2
                Pin 5 (Black) = Red probe
                Pin 7 (White) = Black probe
                LED string #3
                Pin 9 (Blue) = Red probe
                Pin 11 (White) = Black probe
                Look at the female LED connector that goes to male connector CN9402. (Notes: do not plug the female LED connector to the board)
                LED string #4
                LED string #5
                LED string #6
                • anno
                  • Sep 2007
                  • 140
                  • netherlands
                  thanks.
                  i checked the led string and they show vF 135 volt . am i doing something wrong or is there a big problem with the leds? shorted?
                  i get no reading when i check how you said. (blue red probe and white black probe) , i get this reading when reversing .
                  so Blue - Black probe
                  white - red probe
                    [QUOTE=anno;981231]thanks.
                    white - red probe[/QUOTE
                    I based the Blue wire as pin 1 per picture.
                    When you plug the cable into CN9401, is the Blue wire on pin 1 or pin 11?
                    If it is on pin 11, then Blue wires are Cathode.
                    So all the strings light up and with the same Vf of 135V and they are all steady, correct?
                    One thing about LED tester, it only puts out about 30mA instead of 100's of mA, so bad LED's may not show up on the test at low current.
                    You will have to power up the TV with everything all connected back up, then measure the Voltage on each Cathode wire, in this case they are now Blue and Black wires.
                      09-07-2024, 05:50 AM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
