Panasonic tx47as650b no reaction to remote.
  • vikivng
    • Feb 2019
    • 228
    • uk
    #61
    Re: Panasonic tx47as650b no reaction to remote.
    Originally posted by budm
    Just have to match the remote to the TV model.
    Ok,
    anyway thnx alot for the replies and the help.)
    • nomoresonys
      • 12274
      • U.S.
      #62
      Ok then, actually solved 48 posts ago.
      • petehall347
        • Jan 2015
        • 4438
        #63
        its always something simple
        • CapLeaker
          AcuRite 5 in 1 temperature sensor replacement repair
          by CapLeaker
          Got a new victim:
          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
          B: stuck at some temperature and maybe updating once in 12 hrs or so.
          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
          04-15-2025, 01:32 PM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
        • Jackching
          Hisense 65R6107 remote sensor
          by Jackching
          Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
          10-30-2023, 11:35 AM
        • VaporGame
          UE40D5000 no display or reaction to either remote or touch
          by VaporGame
          I recently pulled out my tv from the attic that I remember bricking as a child with the service menu. I remember at the time it came on but didn't react to anything. I have tried a factory reset from the remote and a EEPROM reset but neither worked. I get no led light.
          Here are the things i already tried and did:
          • Checked the power supply (There was a burnt transistor but looking online its a common issue and its not crucial for the tv to run)
          • confirmed the power supply outputs the correct voltages
          • many remote button combinations
          • confirmed the backlight works (lights up when motherboard
          08-29-2024, 11:14 AM
        • groomit
          Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
          by groomit
          I just replaced the battery on a Google Pixel 5.
          After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
          Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
          The rubber seal is on again (as mentioned in various suggestions in other forums).
          This smells like a cold or broken solder joint. So I'd like to reflow...
          06-11-2025, 02:21 AM
