Repairing a Mitsubishi WS 55909 CRT projection HDTV
  • hardwareguy
    • Jun 2006
    • 405
    Got a call on a Mits WS55909 55" CRT projection TV with the continuous flashing green light of death.
    Here is a basic overview of what was wrong.
    One blown pico fuse near the main SMPS transformer on the main power board (the one in the middle of the set). The convergence amplifier had failed. Amp #5 output in the STK 393-110 module was shorted to +VCC.
    Fixed that so I thought the TV would power back up.....wrong!
    The flashing green light of death continued..... some Googling later and I had a lead on another issue...what else but our old nemesis, bad caps, this time in the "DM" module.
    The DM module contains the DTV tuner and all the MPEG decode stuff. There are 3 big chips under heatsinks, a lot of RAM and some ROMs on the board among other things. The problem isn't on this main board, its on a daughterboard inside the same box labeled "DM POWER" This is a simple SMPS that runs on the standby voltages from the main power board. There are 7 Nichicon VR 1000uF 16V caps that like to die. Mine failed without any external sign of failure although others report bulging.
    I pulled one and it measured 3 nano farads! I then knew I had found the issue. As luck would have it, I had exactly 7 Nichicon HZ 1000uF 16V caps in my toolbox and I was able to complete repairs that night.
    The owner and I performed a rough convergence calibration and then he regretted giving this TV to his daughter and buying an LCD. The contrast on CRT just cant be beat. They are still worth fixing.
  • hardwareguy
    • Jun 2006
    • 405
    Re: Repairing a Mitsubishi WS 55909 CRT projection HDTV
    Update....if you find Nichicon VR on the DM Power board, replace them regardless of their apperance. VR is not a low ESR type and as such it has no business being on the output filter of a switch mode regulator that powers what is essentially a computer!
    Im surprised Mitsubishi of all firms would make such a silly mistake on such an expensive set.
    • Maxxarcade
      • Jul 2006
      • 973
      Mitsubishi had cap issues even back in the 90's. Nichicon and Rubycon both were commonly bad at the time. They always smelled like fish when heated with a soldering iron
      That said, once repaired, they always look great. I have several Mits sets in arcade games that have over 25,000 hours on them and still running.
      • DrewPhillips
        Capacitor Diarrhea - Nichicon PL Series
        by DrewPhillips
        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
        03-02-2025, 10:18 PM
      • nick3092
        Mid/late 80's Nichicon Yellow Caps
        by nick3092
        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
        08-28-2022, 03:56 PM
      • chth96
        Is there datasheet for nichicon LXJ series?
        by chth96
        I want to calculate capacitor ESR referring to below guide.
        https://forum.digikey.com/t/calculat...-from-tan/2633
        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
        11-20-2022, 08:11 AM
      • chth96
        Is there any datasheet for nichicon RT(M) series?
        by chth96
        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
        https://www.badcaps.net/forum/troubl...e-been-blew-up
        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
        I have spare console...
        11-28-2023, 03:36 AM
      • spiros.p
        EV dsp,replace the nippons lxz with nichicon fw ?
        by spiros.p
        Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
        12-19-2023, 12:26 AM
