Sony xbr65x900c LED replacement
  • itelite
    • Aug 2016
    • 124
    Has anyone done a LED replacement on the xbr65x900c yet?
    Testing at the cable i have an open line on one of the channels and another that measures out of spec from the rest.
    With this TV being built weirdly to be so very thin im not sure how to safely get to the LEDs. I cant see this panel coming off to reveal a backlight LED array as i am use to seeing.
    If i can get to the array i can replace the faulty LEDS and be good to go.
  • nicholas1110
    • Aug 2012
    • 127
    • usa
    Re: Sony xbr65x900c LED replacement
    There is a YouTube video that will show you step by step how to get to them. The leds come out from the back on this model.
    • timonix20
      Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
      by timonix20
      hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
      the TV starts, LG logo, then nothing (rear backlight)
      no reaction to rear command or infrared
      the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
      I have a chance with a usb procedure or other if you have .bin
      if any people have this main board
      thank you...
      04-23-2024, 01:52 PM
    • FZG
      Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
      by FZG
      Hello there, helpful forum people!
      I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
      On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
      The original part...
      05-10-2023, 11:54 AM
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • labello
      Sony KDL-46ex700 led replacement still same issue
      by labello
      Hi guys I have this tv with this problem, I found it one strip led broken so I decided to change all of them (4) but the problem remains, the tv turn on wit sound led on but after second rebottet and then give me red led blinking (6 times) probably is something in the board broken, i replaced some capacitor that have lower value , take some measurements you're will se on the picture, but I don't have any schematic for this tv. Every reply is accepted! Thank you
      11-11-2024, 12:07 AM
    • lti
      Sony MDR-IF245R transmitter LED replacement
      by lti
      I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
      06-28-2024, 01:47 PM
