Vizio Main bord Question
+ More Options
Posts
  • CraigR
    • Dec 2013
    • 965
    Working on a Vizio E421V0 the sticker on the main board says 3642-1232-0150 (6D)
    I bought an eeprom on eBay for a 3642-1232-0150 and did not work out but the guy is telling me I bought the wrong one because of the (6D) I was told by a guy from ShopJimmy that this would not matter. So who is right? Whats the 6D for?? and nothing is listed with 3642-1232-0150 (6D)
  • R_J
    • 9583
    Re: Vizio Main bord Question
    Maybe the eeprom is not the problem?
    • brucetv
      • May 2015
      • 281
      • united states
      Shopjimmy is right as long as the main board part number matches. The number in the ()is the version number so you have version 6D and most eeproms are not version specific as far as I know. Did you replace U18 and U21 or just the eeprom?
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • RDC55
        Vizio a320-a0 eeprom
        by RDC55
        I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
        Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
        04-28-2021, 09:06 AM
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • fharris1977
        Vizio D50u-D1 Dead: PSU or Main Board?
        by fharris1977
        Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
        03-12-2024, 12:22 PM
