Samsung UE55NU8770 TV Blink Error Codes
  • loadedboyuk
    • Feb 2014
    • 26
    • uk
    Hi everyone
    I have TV Samsung UE55NU8770 Full Smart 4K
    No Pic No Sound, No power up.
    When I plug it in I Get a code flashing out on the stand by LED
    1 Long / 3 Short
    I can not find any service manuals or anything for this TV, and I have never seen a code on the newer models so I'm a little confused.
    Before I get the back off I was hoping someone might have a clue to what is potentially the problem
  • nomoresonys
    • 12276
    • U.S.
    Re: Samsung UE55NU8770 TV Blink Error Codes
    Remove the cable going from powerboard to mainboard and inspect it for damage, such as burn marks or discoloration.
    • loadedboyuk
      • Feb 2014
      • 26
      • uk
      Completely understand your message but Idealy I will to do as much as I can without opening the TV first, software resets, software fault finding. it might not be everones way to doing things, thats just how I like to start
      • nomoresonys
        • 12276
        • U.S.
        "No Pic No Sound, No power up" Doubtful you will get anything like that done with no display, good luck tho.
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
        • michalk3777@gmail.com
          Sharp Hisense - LC-65N7004U Error codes
          by michalk3777@gmail.com
          Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
          Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
          Regards,...
          12-15-2024, 09:20 PM
        • peterwang
          Samsung NP750QGK-KG3US BIOS program error seeking help
          by peterwang
          PCB:BA41-03025A BA92-25486B
          I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
          08-14-2025, 08:15 PM
        • pixelcap
          Pioneer Kuro Pro 111FD 8 red blink error
          by pixelcap
          Pioneer Kuro Pro 111FD 8 blink red LED.
          I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
          So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
          based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
          10-06-2024, 11:26 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
