Samsung led tv UN60J6200AFXZA went black no power no standby light
  • Beanz77
    • Apr 2020
    • Usa
    PLEASE BARE WITH FOR I DONT KNOW MUCH ABOUT FIXING ELECTRONICS. I scrap electronics for the pm so have a little knowledge on it. I have a samsung tv model # UN60J6200AFXZA version EA03. It completely turned off and would not turn back on. No standby light. I'm looking on replacing the board/boards or led back lights. But I'm not sure if it's the power board or the led back lights. I tested the fuse it's good. I then tested the pins on the power board connecting to the led plug. 9 pins 1,2 D+ 3NC 4S- 5NC 6S+ 7NC 8,9 D-. 1,2 had good reading 6 showed good reading. I then unplugged the power and the led plug from the power board then retested same pins. 1,2 showed good reading 6 showed 0. So now I'm not sure my next step. Did I test it correctly? I dont have money to buy a new tv so im looking for any help anyone can give me. Me and the family would really appreciate it thank you
    Re: Samsung tv UN60J6200AFXZA no power no standby light
    What do you mean by good readings, What are the readings?
    What are the Voltage readings of the power supply connector that goes to the main board?
    Also attach the pictures of the whole backside of the TV showing all the boards.
    What is the power supply model number, BN44 -XXXXX? Your picture is too blur to reading anything on the board.
      • 12184
      • U.S.
      Re: Samsung led tv went black no power no standby light
      With tv unplugged from power, unhook cable from powerboard to mainboard, leave it off, plug power cord back into powerboard, do backlights come on and stay on?
      • CapLeaker
        Leaking Member
        • 8147
        Re: Samsung led tv UN60J6200AFXZA went black no power no standby light
        At this point you have to figure out what board your trouble is. What you are describing, could be the PSU or the main board. If the lights come on like in the test from post #3, I would verify that stby power goes into the main board. If stby power goes int the main board, but no little stby led, your main board failed.
        • ChristianBr01
          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
          by ChristianBr01
          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
          04-23-2025, 01:48 AM
        • Kaar3l
          Samsung QLED QE65Q7FNAT only standby light
          by Kaar3l
          TV: Samsung QLED QE65Q7FNAT
          PSU: BN4400940A
          MB: BN94-12832K
          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
          09-24-2024, 01:35 PM
        • Nicktronic
          Samsung UN70NU6070F Standby Light flashes twice
          by Nicktronic
          Hey Everyone,
          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
          03-27-2023, 07:01 PM
        • marcinq
          Samsung UE60KS7000 No Standby Light
          by marcinq
          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
          05-26-2025, 11:36 AM
        • SJX1290
          No Standby Light on Samsung SAMSUNG UE65NU7022
          by SJX1290
          I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
          My main suspect is bad flash memory, ...
          Any suggestions or can someone please​ check dump file, in the attachment
          Thank you...
          09-07-2024, 01:35 AM
