Samsung LE32D400E1W no backlight
  • toty79
    • Mar 2019
    • 42
    • Italia
    Hello to all friends of the forum and well found, I ask help to you more experts to be able to repair as mentioned the above mentioned samsung tv with backlight problem, model Samsung LE32D400E1W with U57E chassis, I have owned the tv for a few years, the last times the backlight flashed cold and then stabilized immediately afterwards, unfortunately now the backlight does not turn on even a flash, audio ok and image present if I point a light on the display, at first I thought it was a problem with the inverter SST320_4UA01 but after having carefully checked I realize that two voltages from the power supply BN44-00438A are missing
    * of which I attach the services manual, this power supply has incorporated a part of inverter, the missing connections appear to me on the connector CNI801 called HIGH (fet) and LOW (fet) both at 0v but I report more precisely all the voltages on the CNI801 below
    CNI801
    pin1) high fet = 0v
    pin2) nc
    pin3) low fet = 0v
    pin4) nc
    pin5) nc
    pin6) nc
    pin7) nc
    pin8) GND
    pin9) OVP = 0v
    pin10) CNT-PRT = 12,15v
    pin11) VCC = 12,80v
    pin12) LD = 11,40v
    I am measuring voltages on the CNI802 and will report them shortly, thanks to all those who will participate in the discussion ...
  • toty79
    • Mar 2019
    • 42
    • Italia
    Re: Samsung LE32D400E1W no backlight
    Here are the tensions on CNI802 which goes to the main, in blue the detected tensions that seem to be all normal, any suggestions and well accepted, at first glance no obvious signs, retouched some welds without result, no short circuit in appearance on mosfets and diodes on the surface, dc voltage on mains filter capacitor 390v stable, thanks to all
      Please attach good clear straight shots of the whole top and bottoms side of YOUR board for us to look at.
      • toty79
        • Mar 2019
        • 42
        • Italia
        Thanks budm for joining us, here are the photos I hope will go well
          Where are the whole backside of the TV showing all the boards?
          • toty79
            • Mar 2019
            • 42
            • Italia
            Sorry here they are, thanks
              1) I assume that the fuse next to the black main filter cap (450vdc CAP) tested OK, corrected?
              2) What is the DC v when measure between the two legs of the main filter cap when TV is turned on? 380 ~ 400VDC?
              4) The inverter transformer drive output will be very high frequency AC which will be too high of the frequency for your meter to read, it may or may not show any activity.
              5) You may want to read these threads since they are referring to the same power supply/Inverter transformer driver board.
                • 12187
                • U.S.
                With tv unplugged from power, unhook cable from powerboard to mainboard, leave it off, plug power cord back into powerboard, do backlights come on and stay on?
                • toty79
                  • Mar 2019
                  • 42
                  • Italia
                  Thank you all
                  budm
                  1) yes tested and everything ok
                  2) Filter cap voltage at tv on 390vdc stable
                  4) Ok if it can help I also have a small oscilloscope, the more I have the less I know how to use it but using it with your indications would be ideal .. thanks
                  5) I read several threads on the forum, even on different TV models with the same power board but no solution
                  nomoresonys
                  I had just read a discussion on the forum, this power supply starts even without the main connected, I did the test as described, the power supply turns on delivers all the voltages as in post N1 and N2 but the lamps remain off
                    • 12187
                    • U.S.
                    Ok, looks like a backlight issue, bad led/s or connection, more than likely.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      What voltage do you have on Pin 16 (EN) of UI801 (SEM2106)
                      Have a read through https://www.badcaps.net/forum/showthread.php?t=32636
                      • toty79
                        • Mar 2019
                        • 42
                        • Italia
                        nomoresonys
                        the TV and an LCD with CCFL lamps would avoid a problem with the lamps as it has a few hours of work, I would get to them by opening the panel but only as a last resort
                        dick_barton
                        I countered the tensions on UI801 (sem2106) and here they are
                        pin1) 0v
                        pin2) 0v
                        pin3) 0v
                        pin4) 0v
                        pin5) 0v
                        pin6) 0v
                        pin7) 0v
                        pin8) 0v
                        pin9) 0v
                        pin10) 0v
                        pin11) 0v
                        pin12) 0v
                        pin13) 0v
                        pin14) 12,80vdc
                        pin15) 4vdc
                        pin16) 5vdc
                        pin17) 0v
                        pin18) 0v
                        pin19) 0v
                        pin20) 0v
                        pin21) 0v
                        pin22) 0v
                        pin23) 0v
                        pin24) 0v
                        as you can see SEM2106 is powered with vcc and enable signal, but almost all the remaining pins indicate 0vdc, could it be a defective ic? have I not piloted? I read the thread suggested by dick_barton where they complain about problems with some zener diodes, I will do a test to see if any zener diode is short, thanks for all the suggestions
                          • 12187
                          • U.S.
                          Lol, oops my bad, didn't look at the picture, there's the inverter board big as life, definitely not an led tv.
                            • 12187
                            • U.S.
                            Look that inverter board over real good, did you check the fuse on it?
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              I think Vref Pin1 (SEM2106) should be 5.0V according to another forum. I am suspecting the SEM2106 as being faulty.
                              It would be worth checking QI801 and QI803 and also mosfets MI801S and MI802S
                              This is from another forum:-
                              the TV turns on, there is no backlight. two transistors mi801S and mi802S were punched on the power supply unit, after their replacement the backlight did not appear, voltages n1 and n2 do not appear on the PWM sem2106 controller.
                              1st leg vref - 5v
                              14th foot vcc - 12.5v
                              16th leg en - 5v
                              • toty79
                                • Mar 2019
                                • 42
                                • Italia
                                I confirm pin1 (sem2106) vref and 0v like all the restantins of the ic except the 3 pins described in the previous post, checked with the multimeter the diodes mentioned in the post of the user kleini which ZDI805-ZDI804-ZDI801 whose with the multimeter not I am in short circuit, another test I did but I don't know if the measurement could be correct and this black test lead on the frame and red test lead on the cathode of the 3 diodes described above with the following results
                                katode ZDI801 = 4.95vdc
                                katode ZDI804 = 1.7vdc
                                katode ZDI805 = 4.05vdc
                                Can Measures Help Detect a Failed Diode? all suggestions well accepted thanks
                                • toty79
                                  • Mar 2019
                                  • 42
                                  • Italia
                                  Fixed friends and thanks to everyone
                                  replaced sem-2106 with one from recovery the tv returns to work perfectly, thanks
                                    • 12187
                                    • U.S.
                                    Nice job, Dick nailed that one.
                                      09-07-2024, 05:50 AM
                                    • C152Heavy
                                      by C152Heavy
                                      Summary for TL-DR readers:
                                      • VCC pin (18) of PFC...
                                      01-11-2023, 02:53 PM
                                    • sansanpartida
                                      Samsung QE82Q70RAT no backlight
                                      by sansanpartida
                                      Hi everyone!
                                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                      My issue: No backlight.
                                      Model: QE82Q70RAT
                                      Type No: QE82Q70RAT
                                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                      So hopefully, I can fix this cheaper.
                                      05-22-2024, 06:56 AM
                                    • howardc64
                                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                      by howardc64
                                      TV was fixed just after removing Samsung's rear snap cover.
                                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                      Maybe PSU->backlight connector didn't have a good contact?...
                                      07-23-2025, 12:34 AM
                                    • howardc64
                                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                      by howardc64
                                      • Prior owner tried a replacement main board. No difference.
                                      • Samsung 2x red blinking standby LED = panel fault
                                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                      07-19-2025, 10:54 PM
