Toshiba 50L7300A turns on then blue screen
  • notallbad
    • Oct 2012
    • 1190
    Re: Toshiba 50L7300A turns on then blue screen
    Yh, whatever is in the zip file put on the usb stick.
    • notallbad
      • Oct 2012
      • 1190
      Perhaps have a quick look at this recent post
      'LG 42LV355T Blue screen No picture', sound like your problem?
      Could well be!
      I still think you should forget about the fw upgrade for now until we can exhaust all other options.
      • Woollyentity
        • Apr 2020
        • 12
        Tried with just the .fwu, USB formatted to FAT32, exactly according to the instructions that came with the software download. Still the exact same result.
        After connecting it to power, I've tried using the on/off button on the back panel and the TV stays on. As part of the FW upgrade is holding down the Vol- button. Is it possible all four buttons are just not properly connecting?
        All advice greatly appreciated.
        • Woollyentity
          • Apr 2020
          • 12
          This is way more in-depth. What are the differences between the LG's symptoms and the video I originally posted?
          I'll have a go with my multi at recreating some measurements, thanks again.
          With any luck I'll be able to get as specific a diagnosis as yours!
          • notallbad
            • Oct 2012
            • 1190
            well just start by inspecting both sides of the boards closely just to confirm theres no obvious blown components.
            Its a process of elimination.
              Post #1:
              "turns on and displays the Red Toshiba logo"
              Please clarify. Are you saying that you see Toshiba logo on the screen, meaning it shows video for seconds and then goes blue screen?
              • Woollyentity
                • Apr 2020
                • 12
                Originally posted by budm
                Post #1:
                https://imgur.com/a/wdqRLEI
                This^. Basically when I plug it in, the light turns green, logo splash occurs normally, followed by a couple of seconds of black, then blue indefinitely.
                The four buttons on the back panel haven't yielded any results or response. The Vol- button is used for the FW upgrade but that process didn't work. The source/menu button hasn't had any effect, and even the power off button doesn't do anything once the TV is on.
                  • 12206
                  • U.S.
                  #28
                  Maybe unplug the ir board, see if tv turns on.
                    I do not see any pictures in your link. Just use the attachment function and upload them here instead.
                    • Woollyentity
                      by Woollyentity
                      I have a second hand Toshiba 50L7300A which, when plugged in, turns on and displays the Red Toshiba logo, but then displays a bright blue screen.
                      I understand this may be a problem with the main board (32L4300 rev 1.02a) but I'm not sure, and they're very difficult to find now anyway.
                      I tried updating the firmware - the USB flashes a few times when plugged in, then nothing happens and the blue screen is still all I get.
                      I also have no remote for this TV.
                      Video of the problem:
                      imgur.com/a/wdqRLEI
                      If you've heard of anything similar please...
                      04-12-2020, 04:00 AM
                      09-06-2024, 05:27 AM
                    • Rav_tangle
                      MacBook Pro 2011 turns on with keyboard light , screen dead
                      by Rav_tangle
                      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                      is this...
                      05-31-2024, 04:09 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • krige
                      asus g750js ms1130c (203) turns on nothing on the screen
                      by krige
                      hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                      03-22-2024, 04:59 AM
