Samsung un40mu7000f dropped, picture right to left darker
  • daxlw
    daxlw
    • Apr 2020
    • 17
    Samsung was dropped. see pictures. Picture fades to the left.
    • 12276
    • U.S.
    Re: Samsung un40mu7000f dropped, picture right to left darker
    May have messed up a tab bond.
    • daxlw
      daxlw
      • Apr 2020
      • 17
      is that a replacement or adjustment fix?
        • 12276
        • U.S.
        Need to do some disassembly to get to them, remove bezel etc., some can be "fixed" by finding a way to apply some pressure on the tab with a shim of some sort, try flex the frame a bit see if the display changes any, not too hard, don't want to crack it.
          • 12276
          • U.S.
          Not sure if the "cutoff tape" method would work, it's been working on symptoms that I didn't think it would tho, lately.
            • 12276
            • U.S.
            Bit of an example there, if you get to the tabs and applying a little pressure and the picture doesn't clear up, then a bad bond is not the problem. Guess just start with taking the back cover off the problem may be obvious, there's more detailed videos, just a matter of finding them, this one gives you the general idea: https://www.youtube.com/watch?v=8l5ORKjQF5U
              • 12276
              • U.S.
              Could try the "cut tape" method first, just for fun, see what happens, sometimes you have to play with the size of the tape to get it just right: https://www.youtube.com/watch?v=7TT8QYeN1s8
                • 12276
                • U.S.
                Suppose it could have just knocked out or knocked loose, looks like about half the backlight leds, whatever the issue, looks like you will need to do some testing if the problem is not obvious when you get the back off.
                • R_J
                  • 9588
                  Going by that partial white line across half the screen I would say the panel is cracked at that point causing the problem you see.
                    09-07-2024, 05:50 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • brithepi2k
                    Samsung UE75TU7020k No picture, Standby blinks 2 times
                    by brithepi2k
                    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                    04-23-2025, 10:05 AM
                  • Dobsuk
                    Samsung UE50TU8000K no picture or lanes on it
                    by Dobsuk
                    Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
                    And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
                    The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes...
                    04-25-2023, 07:34 AM
