Emerson LF501EM4 DS4 no standby led
  • videotronics
    • May 2013
    • 22
    faint chirp when menu button pressed
    all3.3v pulsing to .5v on 2 seconds
    disconnect ribbon to mainboard
    all3.3v 3.3v
    resistance all3.3 to ground 810 ohms
    connect all3.3v to p-on_h2
    p-on+21v 20.9v
    amp+13v 12.5v
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Re: Emerson LF501EM4 DS4 no standby led
    Well, sounds like the main board is dragging the psu down. What is the resistance on the main board from stby to gnd?
    Search for your model number in badcaps. There is one thread not powering on. It has a schematic for your TV. There are a number of reasons why the main board could load the 3.3v rail down. One would be the little ir board, another one could be the zener diode on the tv module is short to gnd, etc...
      You may have shorted cap on the main board.
      Reconnect the cable between main board and power supply board then check the resistance between GND and p-on+21v, amp+13v 12.5v to see if any one of them shows low resistance reading, report the readings.
      You may have the typical bad cap C3214, c3943.
      • videotronics
        • May 2013
        • 22
        connector on resistance to ground
        P-ON+21v 26k ohms
        AMP+13v 6.6 ohms
        ALL3.3v 810 ohms
        connector off resistance to ground
        P-ON+21v 26k ohms
        AMP+13v 1.75 Mohms
        ALL3.3v 810 ohms
        assuming overload on the AMP+13v supply looking at audio output IC3801 and peripheral electrolytic filter capacitors C3829 and C3831
          Does your main board have C3214, c3943?
          Please provide Pictures and P/N of your main board.
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • fharris1977
            Vizio D50u-D1 Dead Set No Standby
            by fharris1977
            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
            12-28-2023, 10:25 AM
          • Crystaleyes
            Samsung BN44-00259A standby question
            by Crystaleyes
            Hi all.
            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
            08-11-2023, 05:15 AM
          • psssst
            Yamaha TSX 120 Standby Problem
            by psssst
            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
            03-01-2024, 07:25 AM
