I am trying to make the backlights to come, and the way I understand I need to unplug connector to main board and put 3.4 volts to pwr on and also inv on/off , is that correct ?
Lg 42ld550v
Re: Lg 42ld550v
Please attach good clear pictures of the boards for us to look at.
You should use 470 ~ 1K resistor between 5V (3.3V) standby power supply output and the control pins, I.E. PS-ON and BL-ON (some time the Dim may be needed too) without main board connected.
But at this point with all the cables in place, what Voltages do you have on the control pins?Last edited by budm; 04-03-2020, 09:00 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Lg 42ld550v
NC 0.1 / Error 0
12v 0/ P-dim 0
12v 0/ A-dim 0
12v 0 inv on,off 0.05
3.5v 3.4/ 3.5v 3.4
3.5v 3.4/ 3.5v 3.4
20v 0/ 20v 0
On 3.2/ 20v 0
when i hit the power button, 0n pin has 0 then once i hit the little black button on the main board i get 3.2 on but no other voltage, the led just flashes slowly,Comment
Re: Lg 42ld550v
You did not label the pins, see if there's a legend/map, list the voltages with tv plugged in but off which is standby then power on tv, see what the voltage does, report both conditions here, don't forget to label the pins, ps-on, 12 volt, gnd, stndby etc.Comment
Re: Lg 42ld550v
"NC 0.1 / Error 0
12v 0/ P-dim 0
12v 0/ A-dim 0
So you are not getting Dim control or BL-ON (INV ON) control signals.
I do not know if ERROR signal is supposed to be normally HIGH or normally LO for normal condition.Last edited by budm; 04-05-2020, 12:11 AM.Never stop learning
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo - Loading...
