We are trying to fix our Philips TV
  • liam101
    • Mar 2020
    • 3
    • Sverige
    We have taken out one of the boards inside. Board# (X) PLTVEL241XAN6.
    As in one of the pictures there seem to be two burned resistors (?) (or whatever they are called) - a blue one and pink one.
    Anyone know how to fix this? Can we replace them? - if so where can we buy the parts, and how do we identify the parts?
    Do we need to buy a new board?
    Any thoughts/suggestions are appreciated.
    Many thanks.
    • Jul 2011
    • 6070
    Re: We are trying to fix our Philips TV
    Welcome to the forum
    The part that you have marked I would check for shorts in and round that area and the mosfet
    If you do not know how to check a mosfet google how to test one
    You do have to have a volt meter
    • R_J
      • 9625
      You likely need to replace Q9101, C9126, R9101 and U9101. But if you can't tell a resistor from a capacitor, it might be best to just replace the board.
      Q9101 = TK6A65D mosfet
      C9126 = 100PF/2kv capacitor
      R9101 = 0.27Ω 2 watt resistor
      U9101 = PF6003AS PFC driver ic
      You also need to check R9113, D9104,R9109 & R9110
      • ngth82
        • Jul 2015
        • 541
        Looks like eBay has three available. Before you purchase, double check ALL of the labels and markings on the board vs the item you are buying and ensure it matches.
        ShopJimmy.com is my usual choice if i can't repair a board... but they don't have this power supply available.
        -Thomas
        I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        • liam101
          • Mar 2020
          • 3
          • Sverige
          Many thanks for all your responses. I'm certainly not an electrician and maybe a new board is the way togo.
          Again your responses are much appreciated.
          • Sharpa
            Repair attempt Philips 55OLED804/12
            by Sharpa
            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
            The symptoms when bought: Philips logo appears then tv turns off
            Things tried so far:
            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
            11-22-2025, 08:30 AM
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • double_DD
            Philips curling iron - is this a common AC cable?
            by double_DD
            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
            08-18-2025, 10:04 AM
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            08-12-2025, 12:54 PM
