Is this a screen defect? LG 39LB5600
  • Ponchojack
    • Mar 2020
    • 15
    I have this TV that seriously burnt an LED strip. It blew out the Main board but the power and t-con boards are ok. (I've swapped them for other good boards) The screen (and scan drive boards) , ribbon cables, and diffuser seem fine and show no visual damage. The screen shows a pattern I've not seen in an LED TV where the top half of the screen is problematic. Attached image.
    Any experienced thoughts?
    Poncho
  • Ponchojack
    • Mar 2020
    • 15
    Re: Is this a screen defect? LG 39LB5600
    uploader rotated the picture, sorry.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      It has surely a bad screen defect, plus another one for the shadow, bin it, better for you..
      • Ponchojack
        • Mar 2020
        • 15
        Yeah, the shadow is a minor reflector issue I can fix, but the rest must be the screen.
        Well, I have some replacement boards and a frame with a new LED set of strips if anyone needs them.
        Poncho
        • handsworth
          • Oct 2015
          • 174
          I have that same tv last week and did a full led replacement. When I replaced the screen, I had the same kind of thing happen. Its one of the tabs on the side of the screen that went bad. If you wiggle them, you may see the screen clear up. If so, tape it in that position. There are posts here that show how to cut them off. They are drivers and THIS IS IRREVERSIBLE!!!!
          • Ponchojack
            • Mar 2020
            • 15
            Thanks so much for this tip. Did you need to use some sort of glue or did they just reconnect when you pressed them?
            • handsworth
              • Oct 2015
              • 174
              I just pressed the ones towards the top and the screen cleared. I used a little black tape to hold it there in that position
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
