T-CON - BN41-02112a
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    T-CON - BN41-02112a
    Hello Guys,
    I'm facing a issue... hope you could help me.
    I have a T-CON board BN41-02112A from Samsung 48inch Curve TV.
    Ok, i have 3 blue LED's they should be stable with the blue light.
    But just only 2 are ON, the 3rd one doesn't turn ON at all.
    Now i apply from my PSU 12V directly to check if something gets hot and find any short on components.
    The PSU Fan spins and board is taking 0.449A and alternates sometimes to 0.588A
    I try to test some test points and i get the right DC Voltage values.
    But at "VON" Pin/Pad i get 0.83mV
    And on Coil "LD02" i have 147.7mV
    The Board CPU gets very hot... But i have to remove the dissipator to check the components... so could anyone help me figure it out?
  • Abu Sayeed
    • Mar 2020
    • 4
    • Bangladesh
    Re: T-CON - BN41-02112a
    Hi Guys main problem is your CPU is Bad, So that your coil is very hoting.
    • William1967
      • Nov 2017
      • 214
      • Netherlands
      BN41-02112A is not the correct number to search for the correct t-con. The number must start with BN95 or BN96. You can find the correct number on the small white label.
      • nrcslim89
        • Nov 2019
        • 129
        • Portugal
        No coil get hot.
        Only T-CON CPU gets very hot.
        And the 3rd LED doesn't come ON.
        The coil "LD02" don't have the right voltage i think that should have.
        • nrcslim89
          • Nov 2019
          • 129
          • Portugal
          Hello, thanks for your observation, but seems at this PCB theres no one white label with BN95/96...
          The only thing i have that could help me identify this T-CON was a printed words in white on PCB. you could check my picture on this thread.
          • diif
            • Feb 2014
            • 6978
            • England
            What's the number on the 32 pin IC next to VON 81223 ?
            Check the resistance between that coil and ground with the power off.
            • nrcslim89
              • Nov 2019
              • 129
              • Portugal
              I have been checked better and i have another problem... on this TV...
              So this is a Samsung UE48H8000SL - Curve LCD with 48" Smart TV.
              So i checked the mainboard at ribbon cable connector, and i don't have the 12V on Input of that connector...
              When i have PSU + MainBoard + T-CON connected only.
              I don't have voltage on main fuse of T-CON (12V), this makes me think better and another problem exists on mainboard of this TV and not just on T-CON.
              So i go back... to mainboard test and measure it, i really have the 12V from PSU... but they don't get into Ribbon Cable ... and i don't understand why...
              Seems on last transistor before Ribbon Cable he don't let pass voltage to T-CON...
              im getting confused...
              The Red Light of TV is always blinking 4 times and looping that.
              • nrcslim89
                • Nov 2019
                • 129
                • Portugal
                Thanks for your reply!!
                Yes the 32 pin IC number is 81223.
                Your correct.
                About resistence, i have 11.46 kOhm
                • CapLeaker
                  Leaking Member
                  • 8214
                  can we see a picture of all your boards?
                  • nrcslim89
                    • Nov 2019
                    • 129
                    • Portugal
                    Sure, look it on beggining of the thread i put the picture of board
                      • 12206
                      • U.S.
                      MMM, that's 1 picture of 1 board, need straight on detailed pictures of each board and one of the whole back to see how they are connected, it's a little work but we're all working.
                        The T-CON PCB assembly is printed on the bar code sticker, see your picture in post 1
                        SK 'BN95-01329A' D27Q....
                        The 'BN41-02112A' is the P/N of the blacnk PCB which can be stuffed to make many PCBA's for the needed LCD panel.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4363
                          • Italy - Milan
                          it is much probably a P-CH mosfet, so the pin at 12v is the source, the pin to the lvds cable is drain, check the other (gate) it will be at 0v 'cause:
                          yes because it's in a error state of software thus shutting down tcon power.. i guess.
                          You can search tcon also with LSF480HQ02.
                          You have a missinig HVIN_R that feeds AVDD and VON, test the t.point to the right of LD02-DD02(big diode)-mark CD17, this is AVDD_R TP and it would be also 0v.
                          Near HVIN_R maybe there's a missing QD01??
                          Next test also to the right of the TCON-processor in the (C) area the TP 1,1v and HVIN_L TP.
                          • nrcslim89
                            • Nov 2019
                            • 129
                            • Portugal
                            Thanks for your reply i will try some as soons as possible but (C) area what do you mean C ?
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • netgearnetgear
                              TCL 43S423 TCON OR PANEL FAULTY???
                              by netgearnetgear
                              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                              08-20-2025, 06:04 PM
                            • alltvrepairs
                              Lg TCon test pins for screen test
                              by alltvrepairs
                              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                              Appreciate your help....
                              06-13-2025, 06:33 AM
