Panasonic 65fx700b intermittent tcon problem
  • pavinski
    Start Hobbyist
    • Sep 2020
    • 3
    Re: Panasonic 65fx700b intermittent tcon problem
    Originally posted by Michaelrobbo
    Caps to removes are c410 to c419 and c400 to c409
    Hey my dude, I've bought this board as having the same issues and am going to be working on it over the weekend, I'm a bit of a novice but I'm okay with desoldering.
    I have a quick question though, which chip is the EPPROM? Just so I don't start dicking around with the wrong thing.
    Thanks mate, appreciate the help.
    • Studi
      • Apr 2015
      Got a copy of the 65inch tcon epprom if any one needs it
      Hi Michael. Yes please.
      Not sure about protocol but can you could attach here?
      Stuart
      • jarsenick1
        • Oct 2021
        • France
        I have the same problem with T-CON board for 65FX700.
        I think I go to buy a TC-Con for 55 inch.
        Michaelrobbo, why you removed 4 caps?
        • saularciga
          • Feb 2014
          • 55
          • mexico
          They are not capacitors, they are resistors.
          • Ben198585
            • May 2018
            • 7
            • Uk
            I fixed one of these t-cons on the same model.
            There's a single S.M cap at the very top middle of t-con.
            Replaced it and fixed.
            I found out by applying 3 seconds of hot air on the t-con just before you turn on the tv, panel will come on and stay on. Until you turn it off, then reheat repeat.
            Or just Replace cap mentioned
            Also 55" tcon won't work, been there
            • Ben198585
              • May 2018
              • 7
              • Uk
              #26
              It was actually a t-con from a TX-65FX600B
              • evde
                • Jan 2022
                • Deutschland
                #27
                was ist eine SM Kappe?
                kannst du ein Foto reinstellen wo man es sieht.
                Danke
                what is a SM cap?
                Can you post a photo where you can see it.
                thank you
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  Danke
                  what is a SM cap? Can you post a photo where you can see it. thank you
                    • 12323
                    • U.S.
                    #29
                    Surface mounted?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      Surface mounted?
                      yes that what i thought, i just google translated evde post to make it easier too understand.
                      (i see hes edited his post now)
                      • Marugovegan
                        • Feb 2022
                        • Netherlands
                        #31
                        Hi Michael,
                        May I please have it?
                        Also, after I changed the boards, now the tv lights up but the image looks like this. Is it normal before flashing the eeprom or did I mess it up while remving the caps?
                        Thank you for taking your time to post a solution.
                        • john@pchire.com
                          • Jul 2022
                          • England
                          #32
                          Heres a picture on what it would do after the TV would warm up you then turned it off and on and then it would work this will fix this problem models also effected are 65fxw724
                          i've had the same problem i replaced the t-conn board that i know works from another TV but now i'm getting this picture can any help or point me in the direction where i'm going wrong
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • hugocarmo
                            Panasonic TX-24A1UN CRT Sound and Input problem.
                            by hugocarmo
                            Hi.
                            I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                            It is imaculate inside, almost no dust or debris inside.
                            The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                            So I started to look for a service manual, I found one, and started from the beginning.
                            Most of the times the caps are the problem so I orderer all the caps for all boards,...
                            04-26-2025, 07:45 PM
                          • renech
                            panasonic TH-42PC77U plasma television half screen problem
                            by renech
                            hello,
                            I hope someone on this forum can assist me.
                            I have a panasonic TH-42PC77U plasma television.
                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                            I have read some posts that suggest the problem is related to the boards on the left...
                            12-12-2022, 06:53 PM
                          • Vebririon
                            panasonic TX-P50V10E 6 blink led problem
                            by Vebririon
                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                            05-17-2025, 10:16 AM
