Panasonic 65fx700b intermittent tcon problem
  • Michaelrobbo
    • Mar 2020
    • 12
    • United kingdom
    Bought the TV about a month ago faulty as it would take about an hour to turn on turns out it was the tcon board as with a reflow has been working great for a month but now the problem is returning upon looking for a replacement there are none on the Internet looked everywhere the only board I can find close is for a 55fx700b which has the same sub model which is a 6870C-0757A but a different main part number mine is a 6871L-5491A and the one for the 55fx700b is a 6871l-5478h anyone had any joy in swapping theses or repaired the original board any help would be appreciated
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Panasonic 65fx700b intermittent tcon problem
    If a reflow fixed the tcon for a month, reballing it should fix it permanently.
    • Michaelrobbo
      • Mar 2020
      • 12
      • United kingdom
      Do you know anyone in the UK that could do it and how much? Reakon I'd do any damage swapping the tco. With the 55 inch model maybe if I swapped the epprom chip over of the old one if all the other parts match uo
      • Michaelrobbo
        • Mar 2020
        • 12
        • United kingdom
        Finally managed to sort this if anyone has the same problem you order a tcon for the 55fx700b 6871l-5478a and your remove 2 sets of caps from the board will put the numbers up tomorrow then use a ch341 programmer to read the epprom of the previous 5491a board and flash it to the new board or just do a chip swap with 24a32 epprom on the board. Now the TV runs great known issues with this model of TV and the tcons are near impossible to get hold of
        • Michaelrobbo
          • Mar 2020
          • 12
          • United kingdom
          Heres a picture on what it would do after the TV would warm up you then turned it off and on and then it would work this will fix this problem models also effected are 65fxw724
            • 12128
            • U.S.
            Nice fix, glad you didn't waste money on a reball, thanks for followup.
              • 12128
              • U.S.
              For those that think a reball is always the answer AND don't presume to tell me you know MORE than Louis Rossman: https://www.youtube.com/watch?v=1AcEt073Uds
              • diif
                • Feb 2014
                • 6978
                • England
                There's a very big difference between faulty Nvidia chips and a failed/cracked bga.
                  • 12128
                  • U.S.
                  You are WEAK, as is your arguments, It is a very good thing that you did not become a defense attorney, they are bga chips, the end.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I didn't think you would understand the difference. The Nvidia chips he talks about were from a specific time and suffered from faulty engineering, he is totally correct in that respect, "Bumpgate" is well documented.
                    As far as I am aware he doesn't repair TVs or consoles that have all suffered from cracked solder joints of the BGAs due to repeated thermal cycling or from tin whiskers causing a short. Occasionally the chips do die, probably from heat but the majority have been fixed with reflowing or reballing.
                      • 12128
                      • U.S.
                      It's not Nvidia chips exclusively BUT I didn't think you would grasp that EITHER and they die a lot more than occasionally, that's why reballing and reflows are not working per your bad advise in this case, which the chip wasn't even the problem.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        My experience of reflowing and reballing is clearly much much larger than yours and yes, Louis is talking exclusively about nvidia chips and why it's pointless reflowing/reballing those. He has little experience with consoles or TVs, which definitely do benefit from reflows/reballing. And from personal experience I can say that the BGAs fail far more then the chips.
                        I'm not sure how you can clam it wasn't even the problem in this case, OP did a reflow that lasted a short while, I'm guessing it wasn't a very good one (no offence OP).
                          • 12128
                          • U.S.
                          If you had average reading comprehension dif, then you would have gathered that it was an eeprom problem that the OP solved.
                            • 20659
                            You can both agree to disagree. Leave it at that !!!!!!!
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              I'm onboard with this theory....a tech disagreement is one thing, but when it sinks to personal level & name calling, its time to knock it off.
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Michaelrobbo
                                • Mar 2020
                                • 12
                                • United kingdom
                                Can confirm the problem was with the dc-dc ic part number sw50212 but couldn't source one it would only work when heated so was failing not the solder so to fix I got a working board off a 55inch and did an epprom swap and removed some capacitors hope this helps people with the same problem
                                • Michaelrobbo
                                  • Mar 2020
                                  • 12
                                  • United kingdom
                                  Caps to removes are c410 to c419 and c400 to c409
                                  • Michaelrobbo
                                    • Mar 2020
                                    • 12
                                    • United kingdom
                                    Got a copy of the 65inch tcon epprom if any one needs it
                                    • Borics
                                      • Jan 2012
                                      resolder U1, known problem with panasonic
                                      • GCM
                                        • Jun 2020
                                        • 11
                                        • Zambia
                                        I'm looking for the Panasonic Tcon board 6871l-5491a.
                                        I would be glad if you could help me with one .
                                        Regards
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • hugocarmo
                                          Panasonic TX-24A1UN CRT Sound and Input problem.
                                          by hugocarmo
                                          Hi.
                                          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                          It is imaculate inside, almost no dust or debris inside.
                                          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                          So I started to look for a service manual, I found one, and started from the beginning.
                                          Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                          04-26-2025, 07:45 PM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
