Vizio E470i-A0 Dark Areas After Replacing Backlights
    • 12206
    • U.S.
    Re: Vizio E470i-A0 Dark Areas After Replacing Backlights
    A couple simple things to try, unplug any hdmi or other accessory cables and just try it with cable or antenna, try plugging tv directly into wall outlet, try a factory reset. See if any of those work.
      • 12206
      • U.S.
      Did you try a different hdmi cable if hdmi is what you are using?
      • R_J
        • 9559
        It looks like the power supply on this model supplies two seperate strings (4 wires to the panel) So there are two seperate series strings, The panel uses 12 strips, 2 across the panel, for 6 rows. It is not possible to have ONE row darker, the power supply has no control over 1 row of 9 led's. It can control the top 3 rows or the bottom 3 rows.
        The best way to confirm it would be to switch the darker row with another row. Your eyes can't tell the brightness when lighting them with the batteries. they all looked bright, but once you put on the diffusers and the lcd panel you can now see the difference.
        • x_orange90_x
          • May 2015
          • 727
          I am using an antenna only, no hdmi or other external source. I also tried a movie on Netflix and it looked the same.
          RJ, I figured that.. but what are the chances of a complete row of brand new LEDs being dim? Furthermore, out of 12 individual sections, the chances of connecting two of them together which both are dim?
            • 12206
            • U.S.
            Another thing to try, turn backlights NOT brightness down to 0 then back up, see if it goes away, I wouldn't run them above 50 percent myself.
              • 12206
              • U.S.
              #26
              Could try: Menu-picture-advanced-smart dimming-off or : Menu-picture-more picture -Active LED Zones-turn off.
                • 12206
                • U.S.
                #27
                Could try wiggling the backlights cable see if there's any change, in case it's a loose/bad connection. You tried plugging directly into wall outlet?
                • x_orange90_x
                  • May 2015
                  • 727
                  Does this model have the smart dimming and active zones features? I haven't seen them in the settings, but then again I wasn't looking for them.
                  I'm running the Backlights at 70%. I did try turning them down to 0 and back up but no change.
                  It's actually plugged into an extension cord which is plugged into one of those light bulb socket adapters. My basement only has one outlet and it's far from my work area.
                  • R_J
                    • 9559
                    What about the distribution board the strips plug into? It may not be the led strip(s) but the connection to them. With the 6 strips (3 rows) connected in series, and supplied by a single voltage source, how can you control (or change) the brightness on 1 strip without effecting the other 2?
                    • budwich
                      • Jul 2015
                      • 3097
                      perhaps it is more likely that the "uniformity" (light output) of the replacement leds is not up to "spec".
                        • 12206
                        • U.S.
                        #31
                        I would try plugging straight into a wall outlet, just to see if maybe it's having a problem with the extension cord setup if those adjustments below don't work..
                          • 12206
                          • U.S.
                          #32
                          User guide: maybe check page 25 section 5 to turn off that ambient light, smart dimming and all that crap: https://cdn.badcaps-static.com/pdfs/...802bc0702c.pdf
                          • x_orange90_x
                            • May 2015
                            • 727
                            I just tried all of those different settings, and also plugging into outlet. No change. I suppose the only option I have is to take the panel apart again and try to get the Backlights on with diffusers in place without the screen.
                            The only way I could see it being an led strip issue is if the voltage is governed by the preceding led. That would mean the very first led in that strip coming from the plug would have to be "weak", limiting the rest of the row to that same voltage. I'm sure this isn't how it works though, because a burnt out LED in the middle of a strip doesn't prohibit the following LEDs from working. I find it unlikely that the entire row (L1/L2 AND R1/R2), randomly connected together out of dozens of possible configurations, would be subpar in comparison to the rest. IF it IS possible that the first LED is undervolted and limiting the rest after it, that would make sense.
                              • 12206
                              • U.S.
                              #34
                              Doubt it but could try unplug wifi module and see if that does it.
                                • 12206
                                • U.S.
                                #35
                                Beginning to wonder if it could be a mainboard problem?? After reading post #48 there: https://www.badcaps.net/forum/showth...t=55317&page=2
                                • x_orange90_x
                                  • May 2015
                                  • 727
                                  The LEDs are plugged directly into the power supply, so if suspect that before main. FYI, I realized tonight this TV doesn't have a TCON... Irrelevant, but figured I'd make note of it.
                                    It is LCD so it must have T-CON, your panel may have integrated T-CON.
                                    • x_orange90_x
                                      • May 2015
                                      • 727
                                      Will I finally fixed it! The picture are attached and they pretty much say it all... The broken trace was unexpected, but nonetheless fixed.
                                      • R_J
                                        • 9559
                                        That would do it. Good to here it is Finally fixed. Looks like a screw was installed in the wrong place.
                                          • 12206
                                          • U.S.
                                          #40
                                          Damn, I thought there was strips that were not lighting up in post #16, 3 of them looks like, so who put that screw there??
                                          • x_orange90_x
                                            Replacing backlights in Vizio V755-J04
                                            by x_orange90_x
                                            I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                                            I have not replaced...
                                            12-03-2024, 07:03 AM
                                          • bpcannan
                                            VIZIO M557-G0: Backlights or ???
                                            by bpcannan
                                            'Morning,
                                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                            10-29-2023, 06:36 AM
                                          • csmith
                                            Vizio-D50u-D1 Pulsating Backlights
                                            by csmith
                                            This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                            Am I looking at a defective strip? Thanks in advance.
                                            11-07-2024, 02:56 PM
                                          • triplefour
                                            TCL 75S421 has sound but no backlight not even a flash
                                            by triplefour
                                            TCL 75S421
                                            PSU BOARD: 40-L402H8-PWD1CG
                                            it shows not even a flash of backlight when powering up.
                                            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                            with mb connected, PSON...
                                            11-17-2023, 09:54 PM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
