Sharp Aquos LC-70LE650U - Dark screen, ghosting. Confused, thought it was fixed
  • twikii
    • Dec 2019
    • 9
    My Sharp Aquos LC-70LE650U was having an issue where the right half of the screen was dark and had latency/ghosting issues. I did some research and found that it may be due to a loose cable, so I took the TV apart and tightened the visible cable connections. When I turned the TV on again, the picture was fixed! I let the TV run for awhile to make sure it wasn't an issue that would come back once it had been in use awhile. It seemed like it was fixed.
    Today, my family helped me hang the TV up. Once it was on the wall, I tested it again and the picture was just fine. I went out for the day and came home...I turned on the TV, and the issue was back! I thought I had fixed it, but I guess not! Maybe it wasn't the cable connections after all? Is it normal for an issue like this to come and go?
    Here's a video showing the issue:
    https://photos.app.goo.gl/xgb43KsM5vRvHbpv7
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp Aquos LC-70LE650U - Dark screen, ghosting. Confused, thought it was fixed
    there are small cables in the bottom corner of the panel (on each side). They interconnect the bottom edge boards to the side edge boards. Check to ensure that they are seated properly especially the one associated with the side that is darker. IF that doesn't resolve the problem, then the likely problem is an issue with the tabs along that side. There are lots of posts about this type of failure and the "save" by removing the tabs on the faulty side. BUT this is a one way operation and can't be backtrack so do some further reading and checking. A further check is to unplug the corner cable ( one at a time, power off of course) and check the result. Go from the results.
    • twikii
      • Dec 2019
      • 9
      Finally got around to working on this. Should I need to disassemble it more to get to the plugs you mentioned? I'm not sure what to do from here.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4462
        • Italy - Milan
        Which type of knowledge you have in this field? I think you have to, after doing the simple checks like connections on flat cables, to interrupt the VCC that feeds the side COFs, if this is a martian language for you, better that you sell tv for parts..
        • twikii
          • Dec 2019
          • 9
          As far as I understand, all that needs to be done with this TV is either tighten a loose cable connection, or clip off some tabs.
            • 12276
            • U.S.
            Don't part it out just yet, someone will help you with testing.
            • budwich
              • Jul 2015
              • 3097
              what cable connections were you referring to in your original post???? It doesn't appear that you have taken anything apart on the back of the tv at this point and with the above question and posted picture.
              Your tv is likely saveable so don't part it out... that suggestion is coming from people just looking for a cheap parts supply. There are lots of posts in this forum about this type of problem. It could be a problem with internal cabling as I mentioned (you need to remove the plastic frame / guard to expose the bottom edge boards of the panel and the corner cables thereon) or possibly a problem with the bonded tabs on the panel.
              • scubacamper
                Sharp Aquos LC-70C6400U Half Screen Dark
                by scubacamper
                I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                05-03-2025, 12:19 PM
              • sefoster
                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                by sefoster
                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                11-20-2022, 09:29 AM
              • jonah1024
                Sharp Aquos LC-40UG7252E LCD TV burn in?
                by jonah1024
                Hello!
                I'm a few days old into this TV screens repair universe so please bear with me.
                Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                - I did a factory reset as well...
                07-16-2024, 04:23 AM
              • klassic
                Sharp Aquos LC-60LE635E three blinks
                by klassic
                Hi community,
                I will describe my problem with a TV in those short following terms to be the most precise :
                What i have :
                power board DPS-162KP-1
                main logic board QPWBXF733WJN2
                symptoms :
                white led light logo at startup,
                after 2 minutes, blinking 3 times a row, repeating
                no backlight (and apparently no picture, checked panel with flashlight)
                no startup sound
                powerboard investigations :
                1-2 PNL : 0v
                3-4 GND
                5-6-7-8 UR : 13.15v
                9-10-11-12...
                10-24-2023, 01:39 PM
              • foxyUK
                Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                by foxyUK
                Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                10-22-2024, 10:27 AM
