Hisense 42K20E Backlights fade to off - Had image
  • x_orange90_x
    • May 2015
    • 764
    So the backlights light up on power on, then fade to off. I can see an image on the screen (No Signal). I've checked voltages of the LED connector and nearly all of the caps. None of the capacitors have any where near the rating including the main. The LED strings don't even have the same voltages. I've attached a pic of the power supply.
    Here are the voltages:
    C810 = 155v
    All of the following are 128v-130v
    C910
    C915
    C953
    C952
    C955
    C951
    The following are at 11.8v
    C922
    C907
    C923
    C908 = 14.66v
    C905 = 14.7v
    The LED connector has
    1+ = 130v
    2+ = 3.8v
  • CapLeaker
    Leaking Member
    • 8352
    Re: Hisense 42K20E Backlights fade to off - Had image
    bad backlight leds in the second string.
      Looking at the board, it looks like The LED strings are connected in series so the 1+ (Anode) will not be same as the 2+ (Anode).
      1+ (Anode) is fed by the LED V boost converter, the 1 - (Cathode) should be connected to the 2 + (Anode), the 2 - (Cathode) goes to ground via PWM controlled MOSFET and current sensing resistor.
      Please upload good clear pictures of the whole backside of the board.
      • x_orange90_x
        • May 2015
        • 764
        I forgot that I posted this same issue over 2 years ago and hadn't continued with diagnostics. Please refer to the following link, especially the last few posts about the BRI voltage. I never continued because I didn't have a 1k resistor, and I still don't. Is there an alternative to doing this without the resistor, or is it absolutely necessary?
        https://www.badcaps.net/forum/showthread.php?t=63913
          You should cancel this thread then and go back to the original thread.
          • x_orange90_x
            • May 2015
            • 764
            I was thinking the same. How do that?
            • x_orange90_x
              • May 2015
              • 764
              @budm please check the old thread. I've made some very interesting discoveries.
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
              • jason123
                Hisense 65R6E3 double-image / horizontal strips - TCON?
                by jason123
                Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                07-19-2025, 08:07 AM
              • dicky96
                HP Elitebook Screen blank - backlights but no image
                by dicky96
                Hi guys
                I'm trying to fix this laptop screen
                Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                OK so I have the original screen which works but has lines across the bottom quarter of the screen
                I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                04-28-2021, 07:30 AM
                HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                09-06-2024, 10:56 AM
