onn. (Element/Walmart) 32" LED add missing PC audio jack?
  • bluto
    • Oct 2007
    • 560
    I picked this up yesterday at Walmart, a 32" LED TV (model #100002458) for just under $100 to use in my shop. A few months ago, the older models used the 'Element' brand name but apparently now they go by 'onn'. Either way it looks like they are all made by Tsinghau TongFang (THTF) Global. The main board is MS35533-ZC01-01.
    Unfortunately it looks like on this one they had to leave off the PC audio 3.5mm input jack to save a few cents per unit. The older models all had this included. I took the cover off and there is clearly an unused location to receive the 3.5mm connector. I tried soldering a cable with a 3.5mm plug to the three pads (the center pin at the back of the solder pads is ground) to see if it would play audio through the speakers but it did not work. There are some other components missing like Q500, Q501, R76, C323, etc. near the connector. Other than those, I think I can trace the one channel back to the main CPU. Does anyone know the best approach to figure out what components are needed and add them back? Maybe even a small perf board with regular through hole components for the transistor, resistor, capacitor, etc. could be used and then all one would have to do is solder the two audio wires to traces leading to the CPU.
    I did play around with the setup menus and the audio screen appears to be active on the PC/VGA input the same as on the Component video input, so I am hoping that the audio is not muted in the firmware for this input. I looked in the service menu and could not find any settings that might change this. So if I could figure out the circuit, I think there is a good chance the PC audio input would work.
  • R_J
    • 9551
    Re: onn. (Element/Walmart) 32" LED add missing PC audio jack?
    Get a VGA to HDMI converter, That would be the easiest
    here is just one example https://www.amazon.ca/FOINNEX-Conver...129WR1Z5PAAFT4
    This one is made by ONTEN, It takes the VGA and audio and converts it to hdmi, it uses a usb port for 5 volt power
    • bluto
      • Oct 2007
      • 560
      I dug into this a little more and I think the main SOC is a TSUMV59XUS. It is amazing that all of the inputs (HDMI, analog audio & video, USB, etc.) get fed directly into the chip where it does all the signal processing and outputs the LVDS signal directly to the panel. I found a service manual of another TV that uses the same chip and it showed all of the circuits for its inputs and outputs including the PC audio input. If it is to believed, then all I need to feed into the SOC's audio input pins is two resistors and a capacitor for each audio channel coming off of a 3.5mm connector. I am going to give it a try and see if it works.
        I would try feeding one of the Analog line (L or R) and see if the sound will come through or not before putting lots of parts.
        • bluto
          • Oct 2007
          • 560
          So here is what I tried (be sure to zoom in to see the annotations):
          I did the same wiring for both channels but only one channel is fully visible in the photo. I removed CD61 (the top of it and the pad to the left were grounded). I added a bridge to the pad to the left of the removed capacitor. Now I had continuity all the way to the SOC. I noted that both channels had a 30k resistor and capacitor pull down to ground on each trace leading to the SOC. I left those alone. I added a 10k resistor for each channel in the input plug holes. So now the input will go through a 10k resistor, then straight to the SOC with the existing resistors and capacitors (pull downs?) going to ground as noted above. Everything looks good in my estimation as it matches pretty closely the circuit in the service manual schematic.
          But when I hooked up an audio signal to the three input pins, I got nothing. Not even one little crackle or a pop. Any thoughts before I give up on this?
          • R_J
            • 9551
            Did you have a vga signal going to the vga jack? sometimes the video must be present before you will get audio.
            • bluto
              • Oct 2007
              • 560
              Yes sir, I did try it while displaying a picture on the vga input. I can adjust the volume, toggle the mute, etc while on this input which makes me believe that it wants to work. So I was hoping for some comments about how my circuit was wrong. If not I suppose that it is still possible that this audio input is disabled by the firmware on some other level.
              • R_J
                • 9551
                You may need to try and get into the service menu somehow. I'm not sure ok this but worth a try:
                Try MENU-1-1-4-7
                • bluto
                  • Oct 2007
                  • 560
                  Yep MENU+1147 works to get into the service menu. Also MENU+0000 does the same thing. I looked all around in there but did not see any settings for audio inputs. Oh well it was worth a try but I give up now
                  • samson7point1@yahoo.com
                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                    by samson7point1@yahoo.com
                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                    The player processes the audio signal using two different reference frequencies. The "R"...
                    04-30-2024, 11:22 AM
                  • Jofka
                    Intel DX79TO missing element
                    by Jofka
                    hello, I have a problem with the motherboard DX79TO, where the element next to the CPU backplate is missing. I haven't find a schematic or anything related to the motherboard anywhere.
                    thanks in advance​
                    01-06-2024, 06:51 AM
                  • mitsu2k
                    Repairing Kenwood XR900-5 car audio amp. Can't identify missing part
                    by mitsu2k
                    Hello folks, I am trying to repair this Kenwood XR900-5 power amp. Someone else had previously worked on this amp and tore off a transistor (Q982, pad and all) and I cannot identify what it was without a schematic or service manual. The one near it is an 2SCR533 NPN. I am wondering if the missing one is likely to be the same or a PNP? Can anyone make a good guess based on the photo?...
                    12-23-2023, 02:09 PM
                  • i_am_patch
                    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                    by i_am_patch
                    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                    04-30-2024, 08:20 PM
                  • ugamazing
                    820-02020 PPBUS_AON missing
                    by ugamazing
                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                    02-05-2025, 04:21 PM
