Sony KDL-55EX640
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    Sony KDL-55EX640
    This TV came with a defective LED, I fixed it, now is working but has a high frequency noise. When I touch a transformer leg (the yellow one on the right) the sound decreases.
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Sony KDL-55EX640
    Have exact same tv with 3 bad LEDs. how did you fix edge LED strip ? replace LED or whole strip ? need part number of LED (5.7 volt).
    edge LED strip part # is LJ64-03374A - can't find them anywhere.
    My panel is #LJ96-05960A.
      • 12192
      • U.S.
      Maybe that: https://www.ebay.com/itm/2pcs-New-55...-/274054349835
      • ajshoe
        ajshoe
        • Dec 2012
        • 477
        • usa
        I saw that earlier - but there out of stock. anyway of finding the actual LED part # 5.7 volt LED ? I can solder flow new ones on the strip.
        • diif
          • Feb 2014
          • 6978
          • England
          There are no part numbers for the individual LEDs. There are plenty of strips in China though, my search engine is full of vendors However not everything is being shipped currently due to Coronavirus.
          LEDs are identified by their size, colour temperature measured in Kelvin, voltage and current. Plenty of options to choose from on Aliexpress but again, Chinese shipping issues.
          • ajshoe
            ajshoe
            • Dec 2012
            • 477
            • usa
            https://www.ebay.com/itm/5-PCS-FOR-R...8AAOSwyd9dXX9~
            found these (in USA) - think they will work.
              • 12192
              • U.S.
              They are 6 volt 7030, looks like a match.
              • alfredomfr1
                • Oct 2014
                • 318
                • usa
                I replaced with another of the same size
                  • 12192
                  • U.S.
                  Do you mean you replaced the led??
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    One thing to realize on this set is if the LEDS are bad - the set can act funny on startup and while running. This set would turn on, no video, and then after some time freeze up (video), then comeback on, and cycle several times until red indicator light comes on and blinks 6 times. Set would act as if shutting down and then rebooting.
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                    • adelage
                      220v Led strip flickering
                      by adelage
                      Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                      I know that the best solution would be to get a voltage...
                      11-03-2024, 09:49 AM
                    • itelite
                      Sony XBR-55X850D LED strip replacement
                      by itelite
                      Does anyone have the procedure for replacing the LED strips on a Sony XBR-55X850D? It's a sidelit TV so hopefully doesn't require complete panel removal and all that, but its a Sony so who knows.
                      I cant find much info on any one having done it before and would love to take a look at what im in for before i decide to take on the job.
                      07-07-2021, 10:38 AM
