when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    Originally posted by R_J
    What are the voltages on IC951? something is wrong in that circuit, that is why there is no regulation happening. Maybe shorted C955,C954? I guess it might be PC901? if you don't have one try exchanging PC902 with PC901.
    IC951= 6.60v I use ground of C951A
    I un solder PC901 now I measure that pads. Still same voltage.
    I replace PC902 with 817A optocoupler. Still same voltage.
    How can I check if C955,C954 are shorted. Can I lift one pad of cap?
    • R_J
      • 9579
      Just check C955/954 in circuit.
      • R_J
        • 9579
        • Nish
          • Sep 2013
          • 124
          IC951 all 3 pin has 6.60v. But cathode is GND.
          I check both end of cap is 6.60v
          Using ground of C951A
          • R_J
            • 9579
            You needed to replace PC901 NOT pc902 I only suggested exchanging them if you did not HAVE ONE.
            • R_J
              • 9579
              Install a TEMPORARY jumper wire in J14, as the power supply board does NOT connect the negative side of C951A/B to the negative of IC951. WITHOUT this connection, the power supply standby 5 volts has no reference.
              I suspect that the two points only get connected whn the main board is connected, something only Philips would do.
              The grounds I marked in Blue, DO NOT connect to the grounds I marked in Green, this is why the supply has no reference and why the output is too high. Installing the J14 jumper should result in a stable +5 volts.
              • Nish
                • Sep 2013
                • 124
                Sorry I miss type. I replaced PC901. By the way I will replace c954. But value is 0.1, is that uF or nF?
                • R_J
                  • 9579
                  Had you told me the voltages on IC951 earlier, I would not have suggested the capacitorsT he caps will be ok, Install the jumper wire I suggest this will fix this issue.
                  • Nish
                    • Sep 2013
                    • 124
                    • R_J
                      • 9579
                      Why??? Just put the original one back in. THEN add the jumper Like I suggested. Look at the schematic... then check the resistance between C951 ground and ic951 ground. If the grounds are not connected together how can it work?
                      The cap is likely .1µf
                      • Nish
                        • Sep 2013
                        • 124
                        I am outside now, I will do the jumper and update later. Thanks
                        • Nish
                          • Sep 2013
                          • 124
                          I install jumper at J14. The C951A ground and IC951 ground are connected together. Now I have IC901 cathode is 6.60v and ref is 1.4v. PC901 still pin 1 and 2 are 6.20v.
                          I checked around IC951
                          R955 = 1.4v
                          C955 = 1.4v (which is connected to ref of IC901)
                          C954 = 1.4v (which is connected to ref of IC901)
                          ZD907 = -5v
                          • Nish
                            • Sep 2013
                            • 124
                            Yes I put back the original one
                            • Nish
                              • Sep 2013
                              • 124
                              Is there anything I can do further with this board?
                              • R_J
                                • 9579
                                Did you ever replace C951? The feedback circuit is very simple I don't know what could be causing it not to work, Have you checked that all the resistors have the correct resistance, even R952.
                                R954 and R955 set the voltage for the reference pin on ic951. If the voltage on C951A is too high (or has too much ripple) IC951 should start to conduct and lower the voltage on PC901 pin2, this lights the led in PC901 telling ic901 to lower the voltage, this is how it regulates.
                                As you can see, if the feedback is not working, IC901 operates full, and the result is too high a voltage on ZD951/C951A. If it was'nt for ZD951 (6.2v zener) clamping that voltage it could be 10 volts or more.
                                The problem is in that feedback circuit.
                                • Nish
                                  • Sep 2013
                                  • 124
                                  Sorry, I didn't have internet for 3 days....
                                  No I didn't replace C951.
                                  R952 = 1.991k
                                  R954 = 6.01k
                                  R955 = 2.951k
                                  "*set the voltage for the reference pin on ic951." Am I using external power supply at what voltage, while the board plug in the outlet? I am confused
                                  • R_J
                                    • 9579
                                    What I said was that R954 and R955 set the voltage for the reference pin on ic951, thats how the those reference ic's work. R954 and R955 form a voltage divider, So when the voltage on the top of R954 increases, the voltage on the other end of R954 increases, this will cause IC951 to turn a bit more lowering the voltage on PC901 pin 2.
                                    But this is not happening so the led in PC901 never turns on.
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      I have replaced R954. Now the voltage attached images.
                                      Across ZD907 = -3.0v
                                      Across C906 = 16.20 solid
                                      Across C912 = 11.21 solid
                                      Across C951A =5.38
                                      • R_J
                                        • 9579
                                        That looks like it is working ok. Now check the voltage across C906 to see what it reads. To turn on the rest of the power supply you would need to connect P-ON-N1 to AL+5V
                                        • Nish
                                          • Sep 2013
                                          • 124
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • kalilinux25
                                            Lenovo Thinkpad T410 no power
                                            by kalilinux25
                                            DEVICE: Laptop
                                            Model: lenovo thiinkpad t410
                                            Board Id: 09A33-3 48.4FZ09.031
                                            NZM1H-8
                                            ISSUE: NO POWER
                                            From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
                                            07-13-2025, 07:56 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
