when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    Originally posted by R_J
    What is the number or letter on the diode? You may need to clean the top with alcohol to read it,
    There is no datasheet for the ic, but C912 is rated for 100v so this ic's VCC might be higher than other similar pwm ic's.
    It' a look like G. But I am not sure. I cleaned with alcohol. It's not clear. I have attached picture.
    • R_J
      • 9518
      I can't make it out but there is likely another number before the "G", try looking at different angles to see if you can see anything else.
      The number on the schematic UDZSTE-17, SHOULD have the voltage after this number (ie: UDZSTE-1722, 22v zener)
      Some of the zeners that I looked at that end in G, like WG are only 10~11 volt which is normally too low a voltage
      • Nish
        • Sep 2013
        • 124
        I think it's broken. I cannot see any other mark on it.
        • Nish
          • Sep 2013
          • 124
          Which one should I buy and try.
          • R_J
            • 9518
            Without a number or voltage rating, it is a guess, Too high a voltage and you will exceed the ic's VCC (which we don't know without a datasheet) and without the full number from the diode its a guess. I would try around a 20 volt zener diode.
            A lot of the infineon ic's (which this is but likely custom) have a max vcc of 22v
            • Nish
              • Sep 2013
              • 124
              When I lift the zener diode and I have 6.4v at C951A
              • R_J
                • 9518
                So this ZD904 zener WAS bad, Check what voltage you have across C912.
                Also while you are at it, check the voltage across C906
                C951A has ZD951, a 6.2 volt zener across it.
                • will62
                  • Dec 2016
                  • 229
                  • usa
                  #108
                  On another site, someone was commenting on the high failure rate of the DNP005, and recommended that it be replaced with a ICE3BR0665JZ. That ic has a VCC range of 10.5-25v.
                  • R_J
                    • 9518
                    I doubt they fail any more frequent than any other standby pwm, the infineon icexxx fail often as well.
                    But did they actually install this ic in the board and check that it worked properly? Did anyone confirm that the DNP005 operates at 65khz vs 100khz?
                    Most of the Infineon icexbrxxx ic's have a max vcc of around 25v thats why I suggested the 20v zener.
                    • will62
                      • Dec 2016
                      • 229
                      • usa
                      #110
                      That, I don't know. The one asking about the DNP005, did not come back and say there was a problem. It was a pretty rough translation from Spanish, but understandable. BTW, not recommending that the OP go away from the DNP005, just adding that it may have a max VCC of 25v. As you said, a 20v zener is probably OK.
                      • Nish
                        • Sep 2013
                        • 124
                        C912 = 11v to 16v fluctuation
                        C906 = 8v to 21v fluctuation
                        I will order 20v zener diode
                        • Nish
                          • Sep 2013
                          • 124
                          I have soldered 20v zener diode. Still C912 and C906 are fluctuating. But I have 6.18v at C951A.
                          • R_J
                            • 9518
                            It may be doing that because of lack of feedback, Check the voltage across ZD907.
                            You may also need to check the voltage on pins 1 & 2 of the PC901 (note to use C951A negative for ground)
                            • Nish
                              • Sep 2013
                              • 124
                              ZD907 = -4.96v
                              PC901 pin1 = 6.60v
                              PC901 pin2 = 6.60v
                              ZD951 and C951A are gets hot
                              • R_J
                                • 9518
                                So you have no feedback to control the primary so it is trying to output more than the 5 volts on the secondary, That's why the ZD951 is getting hot. It is trying to clamp the voltage to 6.2 volts and thats why it gets hot.
                                First check that D950,951 &952 are not bad or leaky (they are likely ok)
                                Next check R954,R955, if they are ok IC951 could be bad
                                What is happening is IC951 is NOT regulating and bringing pin 2 of PC901 low. Check that PC901 pins 1&2 are not shorted. If the optocoupler is ok, I suspect the apl431 regulator is bad. If you don't have one, check an old switching power supply, they almost all use them but it might be a to-92 case but it would work to test.
                                PC901 has the same voltage on both pins so the internal led is not turning on, If the led does not turn on, the photo detector (pins 3 & 4) does not conduct, lowering the voltage across zd907. and regulating ic901
                                • Nish
                                  • Sep 2013
                                  • 124
                                  D950 = 0.2 ,951= 0.2 & 952 = is not populate
                                  R954 =10k ,R955 = 2.976k
                                  PC901 : when I do continuity test no beep. I checked diode mode pin 1(+) to pin 2(-) = 0.596 and pin 1(-) to pin 2 (+) = 0.608
                                  Unsolder those two pin and measure diode mode pin 1(+) to pin 2(-) = 0.998 and pin 1(-) to pin 2 (+) = OL
                                  But when I measure on the pad of PC901 pin 1 and 2 same voltage at diode mode.
                                  I do not have apl431 regulator now. Once I get new I will update.
                                  • Nish
                                    • Sep 2013
                                    • 124
                                    R_J: I have one AP431,can I use it for test?
                                    • R_J
                                      • 9518
                                      The shunt regulator should be pulling pc901 pin 2 close to ground, When it is working you should have about 2~3 volts on PC901 pin2 and around 4~5 volts on pin 1. with about 1.5 volt difference across pins 1&2 the led would be lit and pin 4 would be closer to 1~2 volts, controlling the ic901
                                      • Nish
                                        • Sep 2013
                                        • 124
                                        I replaced new ic951(apl431). But still same voltage
                                        PC901 pin1 = 6.60v
                                        PC901 pin2 = 6.60v (use C951A negative for ground)
                                        • R_J
                                          • 9518
                                          What are the voltages on IC951? something is wrong in that circuit, that is why there is no regulation happening. Maybe shorted C955,C954? I guess it might be PC901? if you don't have one try exchanging PC902 with PC901.
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
                                          • DriversScrew
                                            Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
                                            by DriversScrew
                                            Hello everybody,
                                            I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
                                            Vin: 5,0V
                                            Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
                                            Pin1: ? (perhaps enable)
                                            Pin2: GND
                                            Pin3: Vout - connected to 3ยต3 coil
                                            Pin4: Vin
                                            Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
                                            I searched many datasheets, but no one seemed to match according the surrounding components.
                                            Best similar parts I found were...
                                            12-21-2023, 07:06 AM
