when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    Sorry R_J. It's my mistake I used 12v ground. Also when I fallow your drawing i got 5V.
    The mistake I made. I use negative of C951A and measure then touching the red probe at 12v pins and ground pins so I got 5v all the place.
    Since I fallow your drawing and explanation I got clear. Sorry about that.
    Now I put the 1k resistor CN2: Pin9-1K-pin12 as per your instruction in the post 29.
    I didn't get any voltage at C906 and D903. I am doing the test on bench.
    • Nish
      • Sep 2013
      • 124
      I measure PC902 pin1 red probe and pin 2 black probes and got 0v.
      Do I need to use same ground as standby voltage pin11 on the CN2?
      • R_J
        • 9518
        The voltage that supplies PC902 comes from the AL+5V and connects to Q910 emitter. Q910 must be switched on by Q905 to supply the AL+5V to the collector and then to PC902, pin1
        This Philips POS service manual sucks and blows. If you look CN2 on Page 43, then look at page 42 CN3002 (this is where they connect together) it gets even more confusing. They swap the wires around so maybe pin 11(5vground) connects to the 12v ground at the main board?
        • Nish
          • Sep 2013
          • 124
          Yes it is confusing. I measured voltage Q910, Q905 has 4.48v and PC902 pin1 and 2 has 4.48v. Something short or I am using wrong ground. I am using negative lead of C951A as my ground.
          • Nish
            • Sep 2013
            • 124
            Q910, Q905 all 3 pin has 4.48v.
            • Nish
              • Sep 2013
              • 124
              I want to remove the Q905, but I have still 4.48. While i unsolder it wonot effect any other parts.
              • R_J
                • 9518
                What are you using for ground when you measure this voltage? Q905 emitter is connected to ground so use it to check the voltages in that area. AGAIN, the AL+5V does NOT use the same ground as the rest of the circuit. so stop using C951A as ground.
                If you want the AL+5V or C951A to have the same ground you need to connect pin 11 to pin 5,6,7,8 Or add the jumper wire J14 next to CN2, Just remember to remove J14 after testing the power supply.
                • Nish
                  • Sep 2013
                  • 124
                  Sorry about it. I have 0V around that are.
                  • R_J
                    • 9518
                    Since you now have the AL+5V, why not install it in the tv and see if it works?
                    • Nish
                      • Sep 2013
                      • 124
                      I did, standby light blinking. I measure standby voltage. It becomes 1.8v not 4.48v.
                      • R_J
                        • 9518
                        That could mean one of two things, there is a problem on the main board killing the 5 volts or the power supply can't supply enough current.
                        Is that measuring the standby voltage from ground to CN2 pin9 or across +&- of C951A. You could also check the standby voltage between pin9 and 11 on CN2
                        The AL+5V feeds 2 voltage regulators IC3601(+1.25v) and IC3606(+3.3v) (page37) maybe one of them is bad?
                        The one ic supplies 450ma and the other 200ma, so the power supply should be able to supply at least 1 amp. So you can try placing a 10ฮฉ 2~5 watt resistor across the standby supply (or across C951A) This will draw about 500ma. and should not drop the 5 volts. If it does drop, then the power supply is at fault.
                        • Nish
                          • Sep 2013
                          • 124
                          Sorry to say I have only 0 017v at C951A, before I solder the resistor.
                          • R_J
                            • 9518
                            So NOW you don't have the standby AL5V any more?
                            • Nish
                              • Sep 2013
                              • 124
                              No I don't have the standby voltage at C951A. But I have 5v at ZD907
                              • R_J
                                • 9518
                                from post #41
                                So you never did have this voltage?
                                Also:
                                Where is this voltage coming from if you do not have standby voltage?
                                • Nish
                                  • Sep 2013
                                  • 124
                                  from post #41 So you never did have this voltage?
                                  I had this voltage before I put it in tv and connected t mainboard. After this now I do not have it.
                                  Also: Where is this voltage coming from if you do not have standby voltage?
                                  I solder 2 wire at C915A and measure.
                                  Now I removed from tv and measuring the voltage at C915A.
                                  • R_J
                                    • 9518
                                    So do you have the standby +5 volts?
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      I donot have 5V at C951A
                                      • Nish
                                        • Sep 2013
                                        • 124
                                        I have 5v from IC901 to ZD907
                                        • R_J
                                          • 9518
                                          So you think that just because you have 5 volts on ZD907 you should have 5 volts for to supply the main board? Have another look at the schematic.
                                          Where is this voltage coming from???????
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
                                          • DriversScrew
                                            Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
                                            by DriversScrew
                                            Hello everybody,
                                            I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
                                            Vin: 5,0V
                                            Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
                                            Pin1: ? (perhaps enable)
                                            Pin2: GND
                                            Pin3: Vout - connected to 3ยต3 coil
                                            Pin4: Vin
                                            Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
                                            I searched many datasheets, but no one seemed to match according the surrounding components.
                                            Best similar parts I found were...
                                            12-21-2023, 07:06 AM
