Panasonic TC-P60ST60 Plasma TV 7 Blink Codes Help
  • jennkel
    • 14
    Re: Panasonic TC-P60ST60 Plasma TV 7 Blink Codes Help
    Originally posted by tvtimmy
    What is stamped on the shorted transistors? Something like DG302?
    For Q402-404 the shortened one is D402 and Q401. For Q421-423 there is no shortened one.
    • jennkel
      • 14
      Originally posted by budwich
      I would go with a replacement IF you can find a "match" and has a "return policy" that is favorable because a lot of "used boards" on the market has "misleading specs" (ie. "good working", "tested / working") where they are just salvaged as is and the seller is just pushing them out.
      As you indicate, you may then end up with potentially two boards, working and non-working, which could be useful in the future. Further, if you go with a replacement board, before installing, you can do some "strategic measurements" (ie. resistance checks) and comparing the two to see which components on the "bad" board are maybe in trouble for future "effort" maybe.
      I found this one.
      https://www.ebay.com/itm/TXNSS1UDUUT...QAAOSwtutcGHAF
      30 day return shipping window but I pay return shipping.
      Looks like it would work for my TV since its for the same TV model. I think my TV was manufactured in October 2013 instead of September.
      • ngth82
        • Jul 2015
        • 541
        In post #18 you said
        "Q421-423, Q402-404 Those were the only ones beeping as far as I could tell. I am not sure how to do the second part you described."
        In post #21 You said
        "For Q402-404 the shortened one is D402 and Q401. For Q421-423 there is no shortened one."
        Can you clarify this?
        I've attached a photo with the FETs, diodes and capacitors marked by color.
        Orange - FETs/transistors
        Red - Diodes
        Blue - Capacitors
        For all of the Orange ones (FETS/transistors):
        1. Set your meter on continuity mode (e.g. it beeps when you have your two leads touching each other).
        2. For each component, there are silk screen markings "G" "E" and "C".
        3. measure with the meter all the possible combinations:
        G - E
        G - C
        C - E
        4. Note down which combinations are shorted, and for which component.
        For all of the red ones (Diodes):
        2. For each component, there are silk screen markings "A" "A" and "K". (two anodes, one cathode, it's a dual diode package)
        3. Measure the possible combinations to see if there are any dead shorts across the diode(s)
        "A" (left side) to "K"
        "A" (right side) to "K"
        For all of the blue ones (Capacitors):
        2. For each component, put the meter leads - one on each pin and see if they continuously beep. If so, there is a short there (or caused by other components that share common pads.
        3. Note each component that continuously deeps.
        It may help if you take the SC board image and mark it up in mspaint
        -Thomas
        I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          What I need to know is what is stamped on the front of the transistors, under the screw hole. Here are 2 examples.
          • jennkel
            • 14
            Red - Diodes
            Blue - Capacitors
            G - E
            G - C
            C - E
            My bad, I thought by shortened you meant without nubs on the bottom sticking out.
            Q402 - All combinations beep
            Q403 - All combinations beep
            Q404 - All combinations beep
            Q421-423 - All combinations beep
            D401 - A to K both left and right side beep
            D423 - A to K both left and right side beep
            C411, C412, C413, C416, and C417 beep
            • jennkel
              • 14
              what i need to know is what is stamped on the front of the transistors, under the screw hole. Here are 2 examples.
              q402 - rjp30y2a
              q403 - rjp30y2a
              q404 - rjp30y2a
              q421-423 - 30f125
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                #27
                If you order them from ebay, make sure you check them in diode mode before installing them. I bought 200 GT30j124 igbt's that thankfully were real and not fake Chinese crap that I use as substitutes for most igbt's. I have been burned by buying fake transistors from all over the world before. PM me if you want to get a few from me.
                • sevciu
                  • Jan 2020
                  Hi Guys, I'm trying to repair the same board.
                  At first inspection it had one blown (exploded) diode (D422 - RFE10BM3S) and 3 transistors in short (Q421, 422 and 433 - 30F125).
                  The closest match for diode I found was RFN 10BM 3S, and replaced both D421 and D422. Note "RFN" instead of "RFE", not sure this makes a difference. These diodes I got from a reputable online AU supplier, I trust they are genuine.
                  For transistors, I could only find the exact part (30F125) on ebay, from China. These arrived last night (after 3 weeks).
                  Got quite excited and installed them straight away. Excitement was short lived, my first board repair failed with a faint buzz. Absolutely disappointing. No bang, no sparks, not even a thread of smoke .
                  A quick tally after second failure is pretty discouraging:
                  - Q421, 422 and 433 - 30F125 are in short again
                  - Q621 - 45F128 short (only one, 2 of the 3 are good)
                  - Q661 - RJP63G4 short
                  - Q402, 403, 404 - RJP30Y2A and D401 - RFUH20 appear to be in short, but I have not yet separated them. Some may be OK.
                  The 2 diodes I replaced appear to have survived.
                  I didn't even know I can get fake components on ebay, ex China. Thanks for sharing this. After reading your posts, I strongly suspect (80%) the 30F125 I got from ebay, were fake.
                  I would need a bit of guidance on what equivalents I could use in place of 30F125? I cannot find them with original name anywhere online, for Australia (RS-Components, Element14 ...).
                  I have not yet searched for the components failed last night, I may need to come back for advice on equivalents for those as well.
                  Also, the other help I need is: What else will I need to replace together with these transistors? I understand there are some small IC and SMD transistors, resistors which usually fail together?
                  Cheers, Sevciu
                  • sevciu
                    • Jan 2020
                    To close my story, after replacing everything listed in previous post with genuine spares from reputable source, I had the board repaired and working OK. However the TV ran into 8 Blinks error code. Eventually I fixed that as well, and the TV is working just fine in my patio as outdoor TV.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      #30
                      Glad to hear you had success!
                      • cloo
                        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                        by cloo
                        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                        After doing a factory reset this problem was gone and the picture was back to...
                        01-06-2025, 06:02 AM
                      • jm1234
                        Panasonic plasma TX-P42ST50 - 6 blinks
                        by jm1234
                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                        I checked that board for any obvious faults...
                        05-22-2024, 06:59 AM
                      • stecos
                        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                        by stecos
                        Hi everyone!
                        I happened several times, in the search for help from the web, to consult this very interesting forum.
                        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                        Having said that I come to the gist of my post on the forum as the title suggests.
                        For my passion for technology I'm now collecting several...
                        11-28-2022, 11:39 AM
                      • Alicat
                        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                        by Alicat
                        Stopped by this site trying to fix my parents Panasonic Plasma TV.
                        Model number is TH-50PZ85U
                        Power comes on and the red power light stays on solid.
                        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                        I also hear a few clicks.
                        I also think my parents said there was a thunderstorm and the TV failed after that.
                        Section 6 in the service manual talks about power and no screen,...
                        10-30-2024, 10:09 AM
                      • Eaglecrest
                        Panasonic plasma color stripe
                        by Eaglecrest
                        I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                        11-05-2025, 06:16 PM
