Panasonic TX-P55ST50E Flash IC??
  • icanic
    • Jul 2018
    • 16
    • Croatia
    Greetings!
    Does someone know where is Flash IC located on panasonic plasma board TNPH0989 2A.
    Is the Flash IC the one rounded in red in attachment?
    I have Panasonic TX-P55ST50E with dead board TNPH0989 2A and have found the same board but for TX-P50ST50B and now I am interested in buying the board and try to replace only the Flash IC.
    Have someone done that?
    Any suggestions?
    Thank you!
  • CapLeaker
    Leaking Member
    • 8352
    Re: Panasonic TX-P55ST50E Flash IC??
    replacing that kind of flash, dumping, copying, programming, erasing, replacing has all been done before. Swapping them between exact your boards, could have been done before, but not to my awareness.
    • andybizz
      • Feb 2021
      • france
      Hello Icanic, CapLeaker, hi all. I have this exact issue. How did it work?
      Did the board you buy from TX-P50ST50B work for your TX-P55ST50E, same I have?
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
