Vizio E70U-D3 - No Backlight
  • hardbox
    • Sep 2013
    • 22
    Customer brought in for has sound, no picture or backlights. Replaced the backlights with set from SJ and the backlights still doesn't turn on. Made sure everything was connected and they are working. Pins 1-5 at CN201 on PS which are the LED_OUTPUTS are reading 0 volts, however am getting the 16 V to main and can see image with flashlight. Also not getting any voltage from main to LED's at CN403. What could cause this?
    https://www.shopjimmy.com/vizio-y838...or-e70u-d3.htm
    https://www.shopjimmy.com/vizio-09-7...-led-board.htm
    Power Supply / LED Board: 09-70CAR090-00
    Mainboard: Y8387136S
  • nomoresonys
    • 12305
    • U.S.
    Re: Vizio E70U-D3 - No Backlight
    Do test #3 below.
    • hardbox
      • Sep 2013
      • 22
      CN201 - Same voltages when off and on for all pins. Indicator light on front of TV changes when I press power. Dark image in background visible with flashlight.
      1. VSNS - 0 V
      2. LED_OUT - 0V
      3. LED_OUT - 0V
      4. LED_OUT - 0V
      5. LED_OUT - 0V
      6. GND
      7. GND
      8. GND
      9. GND
      10. GND
      11. 16VS - 16V
      12. AC-DET - 3.8 V
      13. PS-ON - 4.9 V
      14. 16VS - 16V
      15. 16VS - 16V
      • nomoresonys
        • 12305
        • U.S.
        Check voltage of C1 and C2, put meter on 200 vdc or next one up, positive probe on positive + leg, negative probe on negative - leg, check with power off and with power on, careful not to touch anything with your hands, this is the HOT/DEADLY side of powerboard.
        • hardbox
          • Sep 2013
          • 22
          C1 and C2 both show 167.6 V when on. Then both show 165.4 V when OFF.
          • nomoresonys
            • 12305
            • U.S.
            • nomoresonys
              • 12305
              • U.S.
              Looks like your not getting your boosted pfc voltage when tv is on, think it should be around 400 volts when on.
              • hardbox
                • Sep 2013
                • 22
                Hmm. Getting 0 Volts DC on each side of TCON fuse (F100). *edit* Nevermind, my red probe wasn't placed well. Am getting 12 V both sides.
                • hardbox
                  • Sep 2013
                  • 22
                  So the problem is located on the Power Supply most likely for lack of PFC voltage?
                  • nomoresonys
                    • 12305
                    • U.S.
                    Seems like it, did you check all the diodes on powerboard?
                    • hardbox
                      • Sep 2013
                      • 22
                      D103 and D107 are reading short, will test out of circuit
                      • hardbox
                        • Sep 2013
                        • 22
                        oh, D107 tests good out of circuit, D103 reads short.
                        • nomoresonys
                          • 12305
                          • U.S.
                          Ok, that may be the only problem.
                            PFC Diode D103 and D107 are connected in parallel, so you found the cause of not having PFC boosted Voltage.
                            • hardbox
                              • Sep 2013
                              • 22
                              Replaced D103 SF50JG (600V 5A) with MUR460 (600 V 4 A rectifier). This fixed the problem. Thank you!
                              • nomoresonys
                                • 12305
                                • U.S.
                                Glad to hear it.
                                  Did you replace both of them? They are connected in parallel so both of them should be the same so to match Vf as close as possible.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • Yanleb
                                    Vizio M70-D3 4K with dark spots backlight issue
                                    by Yanleb
                                    I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                    On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                    I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                    03-22-2022, 01:06 AM
                                  • csmith
                                    Vizio-D50u-D1 Pulsating Backlights
                                    by csmith
                                    This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                    Am I looking at a defective strip? Thanks in advance.
                                    11-07-2024, 02:56 PM
                                  • howardc64
                                    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                    by howardc64
                                    Problem
                                    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                    Model & Board Pics
                                    Conflicting Spec
                                    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                    https://www.shopjimmy.com/vizio-gj-2k1...
                                    10-10-2024, 01:16 PM
                                  • JaquesPratt
                                    Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                    by JaquesPratt
                                    I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                    This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                    07-16-2024, 01:04 AM
