SHARP lc-49cug8462ks NO Sound through the speakers
  • jczarniak
    • Oct 2015
    • 179
    Got Sharp lc-49cug8462ks with NO sound through the speakers.
    Sound is working fine on the headphones.
    In the TV menu can't change from HP to HP+TV.
    Any idea what's wrong?
    Thank yo very much for any support.
    • 12323
    • U.S.
    Re: SHARP lc-49cug8462ks NO Sound through the speakers
    Try easy stuff first, factory reset, no go then firmware update.
    • jczarniak
      • Oct 2015
      • 179
      Thank you for your reply.
      Done the factory reset, got the latest firmware.
      Still no good
        • 12323
        • U.S.
        Maybe try heating up or cooling with freeze spray or upside down can of duster your IC chips on mainboard with a hairdryer, see if you get sound even for a bit.
        • jczarniak
          • Oct 2015
          • 179
          Good point.
          I'll try that later.
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            see if audio chip is getting hot
            • jczarniak
              • Oct 2015
              • 179
              OK, I will. Thanks.
              • jczarniak
                • Oct 2015
                • 179
                I downloaded the firmware from manufacturer website.
                Updated the TV.
                Got sound working now but got two pictures on the screen instead of one
                  • 12323
                  • U.S.
                  Hmmm, try another factory reset maybe.
                  • jczarniak
                    • Oct 2015
                    • 179
                    Tried a few times.
                    Still the same
                      • 12323
                      • U.S.
                      Makes me thing that that firmware is buggy, I would email sharp, maybe they will send you the firmware, hopefully they have one that works correctly if it is buggy that is.
                        • 12323
                        • U.S.
                        Maybe try the firmware update with a different usb thumb drive.
                          • 12323
                          • U.S.
                          Update instructions:
                          2ENbUSB software updateUser USB software update• Download the file to the PC.• Unpack the *.zip file, you will get the *.bin file.• Copy the *.bin file to the root folder of the USB stick.The flash drive must be formatted in FAT32 and can not contain any other file.• Turn on the TV.• Insert the USB stick into the USB input of the TV.• Press MENU button on the RC to get to the main menu.• Press ► and go to SETTINGS option and press OK. (picture 1)• Press ► and go to SETUP option and press OK. (pic. 2)• Press ▼ and choose Software Update (USB) option and press OK. (pic.3)• You will get a prompt message, confirm with YES (pic. 4).• Wait until the memory update is completed.DO NOT TURN OFF THE TV DURING THIS PROCESS!• After successful update the TV turns ON.• After automatic TV start, please remove USB from TVNOTE: Make sure you do not leave USB with upgrade file in your TV after successful software upgrade! If you wish to use your USB storage device for other TV functions, please first delete upgrade file from it via PC/Laptop.
                          • soeren
                            A2442 - No sound over internal speakers and no video playback
                            by soeren
                            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                            All happened after the battery ran out of power overall several days when I was on vacation.
                            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                            07-26-2024, 01:24 AM
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • Zonzi
                            Telefunken L70 speakers, one has a nasal sound with less bass
                            by Zonzi
                            Hi everyone !
                            Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
                            I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
                            They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
                            05-31-2023, 12:34 PM
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:30 PM
