Samsung UN55H6300AFXZA TV - Smart TV Logo, then black screen
  • ECNiz
    • Nov 2019
    • 5
    • US
    I have a Samsung UN55H6300AFXZA TV. It was working great until it stopped working a day after a power outage. Our neighbor had to replace their satellite receiver box, so I'm assuming there was a surge in the lines before or after the outage.
    The TV would not power on, the standby light would just blink when I tried to turn it on with the remote. I purchased a replacement main board on eBay. With the new main board installed, the TV will now power up and show the SmartTV logo before going to a black screen. It seems like an improvement. I'm not sure what to do now though. I've tried Mute-8-1-2-Power, and get the same thing. I've also tried Exit (12 sec) - Left - Enter.
    The part number on both original and replacement main boards is B94-07774Q.
    The original board has "PC05" on the sticker and the replacement board has "PC01".
    Does anyone have any ideas of what I could try next?
    Thanks!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8324
    Re: Samsung UN55H6300AFXZA TV - Smart TV Logo, then black screen
    check the tcon. maybe unplug one side off the panel from the tcon, turn the tv on, see what happens, then the same thing on the other side. It may be that the tcon is bad too.
    • nomoresonys
      • 12269
      • U.S.
      And see if you have about 12 volts on each side of the tcon fuse if you have a multimeter and want to troubleshoot, as always BE VERY CAREFUL when working with the powerboard, there are DEADLY voltages on the hot side.
      • ECNiz
        • Nov 2019
        • 5
        • US
        I'll take a look. Would it still show the Smart TV logo on the screen if the TCON is bad? Doesn't the fact that a picture (the logo) is showing mean the TCON is OK?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8324
          A bad ic could work for a short time, then quit. You may need to borrow a oscilloscope and test the lvds on the main board as well. Do the backlights stay on, when it is hung up?
          • ECNiz
            • Nov 2019
            • 5
            • US
            The backlights stay on for ~60 seconds after initial power on. If I disconnect either TCON cable, I get no smart tv logo, just the backlights come on. Voltage on either side of the TCON fuse is ~12.5VDC.
            Any other ideas?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8324
              Does your tv has a wifi module? If it does, disconnect it and power the tv on.
              • ECNiz
                • Nov 2019
                • 5
                • US
                I tried unplugging the wifi module, no change.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8324
                  Well, I guess the only thing you can do is to check the lvds on the main board with an oscilloscope. Probe the lvds pairs and flick the menu on and off all the time on the remote. Does the tv stay powered up without the tcon? Other than that, I’d say you have a bad main board. It almost sounds like a bad or corrupt flash, or bad flash IC.
                  • nomoresonys
                    • 12269
                    • U.S.
                    So with everything hooked up do you have backlights on and just a black screen or they go out in 60 seconds?
                    • Schule04
                      Samsung UE48H6270SSXZG black screen after Smart TV logo
                      by Schule04
                      Power supply is BN44-00709A
                      Mainboard is BN94-07385J
                      Got this TV from Ewaste.
                      Symptoms
                      The power LED comes on when plugged in. After pressing the power button the backlight lights up and stays lit. The Samsung Smart TV logo fades in and out. After that the display stays black and doesn't react to buttons on the TV or remote. TCON board has 3 blue LEDs which are lit. A small part of the backlight seems to flicker when the TV is powered up. TV shuts off after some minutes.
                      Attempted troubleshooting...
                      07-01-2022, 05:56 PM
                    • ovrax
                      Samsung UE50NU7020W TV Stuck on Smart TV Logo with No Display
                      by ovrax
                      Hello everyone!
                      I have a Samsung UE50NU7020W TV with an issue.
                      When I plug it in and turn it on, it displays the "Samsung Smart TV" logo, the logo disappears, and it doesn't respond, no reaction at all.
                      The backlight remains on, but I can't do anything.
                      I've tried unplugging the ribbon cables from the T-con board one by one, but the problem remains the same.
                      Any ideas? I haven't found a similar issue on the forum.
                      Thank you!
                      Ovrax
                      11-01-2023, 07:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                      by JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                      Please help. Thanks in advance!
                      08-12-2025, 11:45 AM
                    • Kiberge
                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                      by Kiberge
                      HI guys!
                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                      04-22-2024, 11:28 AM
