TCL TP.MS6308.PB775 backlight current too high?
  • bdorset
    • Aug 2013
    • 30
    • St Vincent, Caribbean
    Greetings to all, Can anyone tell me how to reduce backlight current on this TCL TP.MS6308.PB775. The Board uses GB98AERN backlight controller IC. The original light bars are burn. It uses two bar in series. Each bar has six LED. The LED are 6V. The voltage across the two new bars 77V and 306ma current. The bars are getting hot in less than 5 minutes so I think the current is too high and the bars will burn soon again. Can anyone help?
    • 12196
    • U.S.
    Re: TCL TP.MS6308.PB775 backlight current too high?
    Thats your mainboard, I don't believe you can get it done on there, current mods are usually done on the powerboard by adjusting resistor values.
      • 12196
      • U.S.
      Tomtech has some he did, there's a few more on the list to the right there, a schematic of your powerboard would help, no tcl's but shows you the gist of it: https://www.youtube.com/watch?v=GrfS...gtd-hcUXG2KjSC
      • bdorset
        • Aug 2013
        • 30
        This is a single board TV, main and power supply together. I cant find an exact schematic for my TV but the attached schematic is very close. It uses the same controller IC in a different package.
          • 12196
          • U.S.
          Ah, I see, my bad for assuming hate when that happens.
            • 12196
            • U.S.
            I don't know how to do it, I think it would help with led lifespan tho, will be watching this one.
              I need to see high res pictures of the whole top and bottom side of the board and also close up of the LED connector to show how the wires are attached to the LED connector.
              • bdorset
                • Aug 2013
                • 30
                Thanks to all who responded to my question and also to all who did some research but did not post a reply. I found the solution from many Russian forum. The solution is to change the resistor at pin 6 (ISET). The resistor on my board was 16.5K when removed. This resistor went from pin6 to ground. I replaces it with a 33K and the current drop to 150ma from 306ma and the voltage across the strips drop to 71V. I had to used Google translate to get the info because its all in Russian.
                  • 12196
                  • U.S.
                  Nice job, thanks for report.
                    • 12196
                    • U.S.
                    Did you get a picture of your fix?
                    • dineshkv
                      • Sep 2016
                      • mauritius
                      gb98aern from pin6 there is 2resistot remove one from them to decrise current
                        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                        by sam_sam_sam
                        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                        I tested the battery cells there are installed right now and they are testing good with no issues that I...
                        02-04-2025, 08:08 PM
                      • howardc64
                        Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                        by howardc64
                        Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                        • Backlight on, no image
                        • Disconnect right buffer board (view from front), left side display comes on
                        • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                        • Buffer board is pretty simple
                        Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                        07-11-2025, 04:04 PM
                      • DrewPhillips
                        SFX PSU - Need High Current on 3.3V & 5V Rails?
                        by DrewPhillips
                        I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                        The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                        02-18-2025, 01:03 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                        Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                        The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                        The bq24745 features dynamic power management...
                        10-23-2024, 02:50 AM
