Sony KDL-50W800C
  • dprit
    • Jul 2015
    • 49
    Sony KDL-50W800C
    Set came in with Audio but no video/OSD. Backlights are lit. I can't see any video using a flashlight. I read somewhere where a blank screen could be a software upgrade problem but customer did not bring the remote to try a upgrade test. Surface mount fuses on the main board seem ok. Any ideas?
    • 12085
    • U.S.
    Re: Sony KDL-50W800C
    Check for about 12 volts on each side of t-con fuse.
    • neilc6
      • Nov 2015
      • 1550
      Check for shorted caps on the panel boards. Probably no tcon on this model.
      https://www.badcaps.net/forum/showth...hlight=40w600b
        • 12085
        • U.S.
        There sure is one on that SO FALSE ASSUMPTIONS ASIDE, dprit is that your tcon board??: https://www.electropartsonline.com/s...oard-unit.html
          • 12085
          • U.S.
          A WISE man once said "I would rather be last with the CORRECT answer THAN first with the WRONG answer.
            Upload good clear pictures of the whole backside of the TV so we can see shwoing the boards what we are dealing with.
            • dprit
              • Jul 2015
              • 49
              There is a T-Con board and the 3A fuse is open. I will replace the fuse and see if it blows.And yes nomoresonys that is the correct T-Con board.
                I would check the resistance of the output side of the fuse with ref to Ground and als check the resistance of all MLC Caps first before putting in new fuse.
                • dprit
                  • Jul 2015
                  • 49
                  I put in a new fuse and disconnected the 2 ribbons going to the signal board/panel. The fuse did not blow but the Sony light at the bottom of the set blinked Red ( It never did that before). Then I took the fuse out and tried it again and as before I had backlights and a normal lit Sony light at the bottom of the set. I'm leaning to something wrong on the T-Con board.
                    But does it blow the fuse if the ribbon cables between the T-CON and the LCD panel are connected?
                    • dprit
                      • Jul 2015
                      • 49
                      Does not blow the fuse with the ribbons hooked up. But with the fuse replaced, I can't power up the set by pushing the power button. Take the fuse out and I can power up. I will try to find a T-Conn board and reply.
                      • neilc6
                        • Nov 2015
                        • 1550
                        Disconnect one side of the ribbon cables at a time and try powering on. If one side shows a picture, there is a panel fault on the side that doesn't power up.
                        • dprit
                          • Jul 2015
                          • 49
                          Unplugging the ribbon cable that goes to the left side of the panel brings up a picture on the right side of the set. I'll check to see if there are any shorted caps on the source board that is loading down the T-Con.
                            • 12085
                            • U.S.
                            It's a good half picture? what do you get when you do the other side?
                            • dprit
                              • Jul 2015
                              • 49
                              Yes it is a good picture on the side that is hooked up and a bright white screen on the side that is not hooked up. And when I switch the ribbons-my set will not power up.
                              • Aakashlimbu
                                • Apr 2022
                                • 5
                                • Nepal
                                Its panel problem .if you open left side ribbon cable and display shows right side then your left side problem..do remove at right side as a same way and watch it.if left side problem then you need to block signal.for more send me a picture of tcon.i will guide you
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                  Surface Mount Fuses Fundamentals Datasheet
                                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                  10-07-2024, 06:07 AM
                                • dkneyle
                                  Sony KDL-46HX850 Can't upgrade/update firmware
                                  by dkneyle
                                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                  09-25-2024, 10:44 PM
                                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 05:27 AM
                                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                  09-06-2024, 05:30 AM
