Samsung UA50f Backlight problem
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi
    Got this samsung UA50f I think the a is because i live in south Africa.
    This set has 9 rows of LED strips . The top 5 rows come on fully bright but the bottom 4 come on dull. The lights are only on for a second or so then they all switch of . and a relay can be heard clicking. I chaned one of the dull strips with the bright one and still the same so I dont think its the LED strips.
    Any help would be appreciated
    James
    • 12229
    • U.S.
    Re: Samsung UA50f Backlight problem
    Can you post good clear straight shot pictures of the whole back and each board.
    • provider10
      • Mar 2016
      • 52
      • South Africa
      Hope these pics help. I think the model in UK is UN50F
      • neilc6
        • Nov 2015
        • 1550
        Check if you have good continuity through the connector. You may also have bad backlights.
        https://www.badcaps.net/forum/showthread.php?t=72299
        • provider10
          • Mar 2016
          • 52
          • South Africa
          The back lights are good as i changed one of the dim set to a position where they were bright and the leds lit up good
            You have FOUR LED drivers so you need to check the Boosted Voltage output of each driver when you first turn on the TV.
            Your pictures are too blur to be able to read any prints on the boards.
            • provider10
              • Mar 2016
              • 52
              • South Africa
              Hope these pictures help. The problem is the set does not stay on long enough to make any measurements
              James
              • provider10
                • Mar 2016
                • 52
                • South Africa
                sorry pics did not attach
                  You are looking to see how high the LED drive Voltage jumps up to when TV is first turned on, so you will have to repeat the test 4 times to see if they all jump up to the same level or not before the protection circuit kicks in. Set meter to 200 Vdc scale or higher.
                  What is the power supply board P/N? BN44-?????.
                  There is Voltage chart printed on the board.
                  EDIT: I now see the board P/N BN44-00624B.
                  Can we get good clear straight shot of the whole top and bottom side of the power supply board?
                    09-07-2024, 05:50 AM
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
