Philips 47PDL6907K/12 Mainboard Replacement
  • KvnTM
    • May 2018
    • 434
    Hi!
    I got the TV in the title. Unfortunately the mainboard died which is a well known failure of those sh*t Philips tv's.
    Now to my question:
    I got a working mainboard from an 47PFL6007K/12 for a very very cheap price and it arrives soon. The mainboard is pretty much the same besides one unpopulated hdmi connector which I don't care about. The board also has a smaller ffc connector for the front panel but the footprint for the larger one is on the board so replacing it will be easy.
    Now to the important question.. Is there a way to flash the matching firmware for my tv? I know you can manually run updated through usb with the .upg file. I read somewhere that you can flash "wrong" firmwares in SDM mode. I already got the correct file for my tv. I also know that you have to enter the panel and option codes. It would be highly appreciated if someone can explain how to do this.
    I'll attach 2 photos for comparison.
    47PFL6007K/12 Mainboard
    I'm talking about the small ffc connector left to the lvds connectors. You can see the footprint for the larger one is there.
    Those are pictures taken from google. I don't have any high res images of the boards.
  • KvnTM
    • May 2018
    • 434
    Re: Philips 47PDL6907K/12 Mainboard Replacement
    bump
    • Diah
      • Feb 2013
      • 6501
      as i know..it passed, but only inter the panel code to the replacement and don't run your original FW. just do FW to the one you replaced to recover the T-CON driver
      • KvnTM
        • May 2018
        • 434
        Ok, thanks. I'll let you know once it arrives. What about the function codes?
        You mean i shouldn't flash another firmware on the replacement board and only enter the panel code?
        The old board is damaged beyond repair and doesn't turn on at all so i can't do anything with it. In fact, the cpu is desoldered from the board. Thermal stress has ripped a few pads from it. Philips didn't really think about their heatsink. It is too small and the cpu cooked itself to death and bent the board which ripped the pads.
        • Diah
          • Feb 2013
          • 6501
          there are no function code. you are going to put used MB not blank manufacture one.
          panel code enough and firmware designed to the used boards. some time hard reset do the job if there no firmware.
          • KvnTM
            • May 2018
            • 434
            AFAIK there are function codes and panel codes on Philips TVs. Mine has two square boxes on the case one labeled option code.
            *Those are named Option Codes and not Function Codes
            I took a picture from the back of the unit..
            • Diah
              • Feb 2013
              • 6501
              you wrote at yours post 4 function code LOL
              Option Code are ready injected at the used one. .. yours Original MB had more option out put.. the used one had less.. both are designed to 3D .. so you will be fine with out Option Code.
              BTW it may come the used one same panel code.. Philips used one-3 source only of Panel manufactures so round 90% the one will come had same code 426.
              • KvnTM
                • May 2018
                • 434
                Yeah I got that wrong in the first time
                OK. I'll give it a show and report back.
                Thanks dude
                • KvnTM
                  • May 2018
                  • 434
                  Welp... I guess I can write this tv off. The seller is an a**hole and tried to scam me. He didn't ship it, doesn't respond anymore, phone turned off. He's answering to my 2nd account though. I'll mess with him for a little bit. He lives somewhat close to me.. Maybe I'll give him a visit soon. Good thing i paid with PayPal.
                  I guess anybody in Germany can relate to "eBay kleinanzeigen" a**holes... Damn i don't know what's wrong with society these days.
                  • Mirenia
                    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                    by Mirenia
                    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                    03-30-2025, 06:47 AM
                  • tuner2000i
                    Philips 65PUS8518/12 distorted image after main board replacement
                    by tuner2000i
                    hello everyone,
                    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                    07-15-2025, 01:15 PM
                  • Rauni
                    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                    by Rauni
                    Hello, this is my first post on this forum, and my first attempted to repair a TV.
                    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                    Read also that we should test what happens if we...
                    10-01-2023, 12:06 AM
                  • AustinComputerDoctor
                    Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
                    by AustinComputerDoctor
                    I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
                    I see backlite is active,
                    but I cannot get the screen to return back to menus , etc
                    This is all after replacing the mainboard...
                    any assistance is greatly appreciated.
                    03-25-2024, 12:43 PM
                  • satinser
                    Philips 32PFL9604H/12 mainboard likely
                    by satinser
                    As soon as plugged in at power socket TV starts up with Philips opening logo, screen then shows HDMI 4, then both picture and backlight go off but TV remains on and if any button on remote is pressed red led blinks fast. If mains plug is removed and plugged back in the same thing happens. Suspect it might be software on main board related issue. If anybody has the software for this model would be grateful. Have corrected many LG mainboards by reflowing at 200c in the oven does anybody know whether Philips mainboards are so oven friendly!
                    05-06-2023, 07:00 PM
