Samsung UN55D6005SF
  • bleed4me
    • Nov 2015
    • 122
    Re: Samsung UN55D6005SF
    Originally posted by budm
    Try having just the BL-ON wire disconnected and everything are back in place so you will get backlights, and if there is no other problem any where else then you should see image and sound and all other functions of the TV, if not then you have more than just no BL-ON signal.
    Ok so BL-ON disconnected and everything back into place when i power on the TV it flashes the splash screen and turns off.
    so no change on that...
    I must ask though if BL-ON is already at a voltage of 0 why would disconnecting it make any difference?
    • bleed4me
      • Nov 2015
      • 122
      The only way I can keep the backlights on is if the mainboard is disconnected from the power board.
        The BL-ON pin on the power supply board has pull-up resistors for performing power supply board self test, when the power supply board is connected to the main board, the main board will keep the BL-ON line low (<1V), when the TV is turned on then the main board allow the BL-ON to high turn on the backlights circuits.
        So at this point you have more than just BL-ON problem on the main board some where. If you check the Voltages at the power supply connectors you will find that some other control Voltages are not there either.
        • bleed4me
          • Nov 2015
          • 122
          Thank you for explaining that! I never understood how that worked but it makes sense now. Much appreciated.
          Does the PSON voltage need to be in the 5v range as well?
            PS-ON: <1V (typ.) = OFF, >2V (typ.) = ON
            • bleed4me
              • Nov 2015
              • 122
              Ok so we at least know that voltage is correct. Which voltages am I missing here?
                You need to check the Voltages at the power supply connector pins that goes to the main board with connector in place but the BL-ON wire is not connected and see if they are all present or not, the chart is printed on the board.
                • bleed4me
                  • Nov 2015
                  • 122
                  Ok I just checkout out all the voltages on the powerboard with everything connected minus BL-ON and all the voltages are the exact same as when the BL-ON was connected.
                    Are you saying you are getting exact same reading in post #5 or what? That is important info to be exact.
                    If you are getting the same readings then you need to disconnect the Dimming control line pin 10 (EPVW) also.
                    Your post #5 readings:
                    Power Supply
                    CNM803
                    Top
                    Pin 1 MC- not in use
                    Pin 2 B13V- 12.67v
                    Pin 3 B13V- 12.69v
                    Pin 4 VAMP- 18.5v
                    Pin 5 VAMP- 18.5v
                    Pin 6 GND- 0v
                    Pin 7 B5V- 5.3v
                    Pin 8 B5V-5.36v
                    Bottom
                    Pin9 MC- not in use
                    Pin 10 EPVW- 0v, At 0V there will be no backlights.
                    Pin 11 NC- 12.6v
                    Pin 12 BLU ON- 0v. it should show 2V or more at this point since the wire is not connected.
                    Pin 13 GND- 0v
                    Pin 14 GND- 0v
                    Pin 15 A5V- 5.3v
                    Pin 16 PSON- 3.3v
                      • 12331
                      • U.S.
                      #30
                      • bleed4me
                        • Nov 2015
                        • 122
                        Sorry it took so long for me to respond its been a day
                        So I have rechecked all voltages and they were all the exact same as post #5. I even replaced the batteries in my meter just in case and all the voltages were the same.
                        Now that Pin 10epvw is disconnected i now get the voltages you were looking for and the backlight stays on when the tv is powered on.
                        Top
                        Pin 2 B13V- 12.67v
                        Pin 3 B13V- 12.69v
                        Pin 4 VAMP- 18.5v
                        Pin 5 VAMP- 18.5v
                        Pin 6 GND- 0v
                        Pin 7 B5V- 5.3v
                        Pin 8 B5V-5.36v
                        Bottom
                        Pin9 MC- not in use
                        Pin 10 EPVW- 3.2v
                        Pin 11 NC- 12.6v
                        Pin 12 BLU ON- 3v
                        Pin 13 GND- 0v
                        Pin 14 GND- 0v
                        Pin 15 A5V- 5.3v
                        Pin 16 PSON- 3.3v[/B][/I][/QUOTE]
                          I expect the backlights to stay on when you also disconnect the EPVW wire, so we do have backlights but nothing is shown on the screen, correct, if that is the case then something is really bad on the main board.
                          Do you get switched 12VDC feeding the T-CON fuse?
                          If not you have lots of problem with this main board, I do not know the exact cause, may be bad EEPROM, FW, BGA issue, etc.
                          • bleed4me
                            • Nov 2015
                            • 122
                            The screen will flash the splash logo then go to a dull lit grey screen.
                            When I check the voltage and fuse F102 on the T-con board i do get a voltage of 12.53.
                              Good, so lets try again with having ribbon cable between T-CON and the LCD panel connected one at time to see what you will get, I want to see if you can get good half the screen and how long the image will stay on the screen.
                                • 12331
                                • U.S.
                                #35
                                Tcon issue?
                                • bleed4me
                                  • Nov 2015
                                  • 122
                                  Ok please forgive the horrible pictures but when i disconnect the left tab and power on i get half the splash logo on the right but now on the left that is white vertical lines start to appear on the screen. Starts off as a single line and the longer it stays on the more that appear. If i disconnect the right side i get the exact same effects just opposite.
                                    • 12331
                                    • U.S.
                                    #37
                                    Tcon issue?
                                    No, seems like a bad mainboard, forgot I already suggested it in post #7.
                                    • bleed4me
                                      • Nov 2015
                                      • 122
                                      So the question is just how bad is the mainboard and is it repairable?
                                        • 12331
                                        • U.S.
                                        #39
                                        Some have but they are not near as easy to fix as powerboards imo.
                                        • bleed4me
                                          • Nov 2015
                                          • 122
                                          Fingers crossed because the mainboard online is nowhere to be found.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
