Is NEC E552 a monitor or TV? IR reciever?
  • Mattmoosh2000
    • Mar 2018
    • 15
    I'm about to dive into the troubleshooting guides and think the E552 is a TV, but i am not sure. It's a Display Screen.
    Got it for $100 I put a new/used main board in it. Speakers weren't working, but headphones were.
    Rebooted it and the inputs are locked.
    Got a universal remote to try to enter 0000 in parental controls, but the brand new universal remote cant find the code. Tried entering them all in manually.
    Thinking it may be the IR reciever... is This tv IR? i heard some remotes are RF?
    Thanks for your time!
    • 12206
    • U.S.
    Re: Is NEC E552 a monitor or TV? IR reciever?
    Looks like it's both, a display screen with built in tuners: https://www.necdisplay.com/p/e552
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      can you not search for the code ?
        • 12206
        • U.S.
        Some remotes won't work with some tvs, do you have another universal you can try with it?
        • Mattmoosh2000
          • Mar 2018
          • 15
          i have tried it with a verizon remote and a GE universal remote from amazon. both with new batteries.
          took a video of the remotes having buttons pushed, to see if the IR LED was coming on. they were.
          tried searching for the code with the setup functions
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you get access using your PC/laptop via RS232
            • Mattmoosh2000
              • Mar 2018
              • 15
              ok. i'll try the RS232
              I have been guessing that input would be blocked aswell.
              does the TV support a USB Keyboard?
              • Mattmoosh2000
                • Mar 2018
                • 15
                It is Locked. It seems all of the inputs are locked. It has a password sign that flashes when ever i try to do anything
                There is a USB input that supports Mp3 and such. It has a more automated interface, but the buttons on the TV don't control it.
                  • 12206
                  • U.S.
                  To un-lock the OSD press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.
                  • Mattmoosh2000
                    • Mar 2018
                    • 15
                    What is OSD?
                    I tried that, nothing... just "password"and a yellow bar, and "input locked!" jumping around a blue screen.
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      is there a firmware update i wonder .
                        • 12206
                        • U.S.
                        OSD is on screen display, it looks like you either need that password or a way around or way to reset the password, thinking there must be a way to do it, for just such cases like this where it's not available or forgotten/lost.
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          this might help .
                          https://factory-reset.com/wiki/NEC_Service_Menu
                            • 12206
                            • U.S.
                            Did you try contacting NEC? seems like they should have a solution if it's just password locked out.
                            • Diah
                              • Feb 2013
                              • 6395
                              the default password for locked paternal or channel are 0000
                              you can use USB keyboard ps2 or air mouse keyboards too
                              • Mattmoosh2000
                                • Mar 2018
                                • 15
                                there is a button, that i dont have, required for each choice.
                                Going to contact NEC tomorrow
                                Plugged in a keyboard, but it doesnt let me enter 0000. going to calll.
                                • Mattmoosh2000
                                  • Mar 2018
                                  • 15
                                  I should have known they would be closed on a Saturday.
                                  No one thinks it is the IR receiver off the bat?
                                  Maybe these universal remotes aren't compatible?
                                  Is there a particular Remote that i should try?
                                  There is a special user interface with the USB function, i believe one can use a keyboard and mouse in that function, but not for tv functions?
                                    • 12206
                                    • U.S.
                                    You tried using the button board on the tv to control it?
                                    • Diah
                                      • Feb 2013
                                      • 6395
                                      Any android mobile / tablet with bulit in IR sender.. by use smart remote APK
                                      it had very rich collection code package for NEC
                                      • Mattmoosh2000
                                        • Mar 2018
                                        • 15
                                        I have tried all the combinations of input, menu, volume and channel up and down. Cant get into the password bar and enter numbers.
                                        my brother has an android tablet. ill get my hands on one.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
