lg 43uh610v schematic
  • vikivng
    • Feb 2019
    • 228
    Hi guys,
    can anyone help me with a schematic for this tv.?
    Im getting solid red standby light with one blink when power button is pressed.
    Power supply seems fine.
    thnx
    Re: lg 43uh610v schematic
    You will get a lot more help if you upload good clear pictures of the whole back side of the TV showing all the boards.
    "Power supply seems fine." Seems fine???
    Are you getting the correct Voltages and correct control Voltages?
    You need to report the Voltage readings of each pin of the power supply connector that goes to the main board when TV is OFF and when power switch is activated.
    You MUST PUT DOWN PIN NAME AND FOLLOW BY THE VOLTAGE READING FOR EACH PIN so we can easily see what it has or does not have.
    • vikivng
      • Feb 2019
      • 228
      Yes..Sorry guys.
      you are correct..
      Iwill do that now.
      thnx for the reply.
      • vikivng
        • Feb 2019
        • 228
        Voltages taken without pressing power button but with tv plugged in.
        Standby light is on.
        P DIM 1= fluctuates between .4 - .6v
        GND=0V
        NEXT PIN DOWN FROM GND fluctuates between 5.4-6.9V
        NEXT PIN DOWN fluctuates between 5.4-6.9V
        gnd=0v
        PWR- ON = 0V
        Pressing power button gives PWR-ON 3.1V FOR SPLIT SECOND.
        • vikivng
          • Feb 2019
          • 228
          Does this make sense.?
          thnx
            13.2V power supplies and PWR-ON should not be going up and down.
            I cannot see the power supply board P/N. I need good clear straight shot hi-res pictures of the whole power supply board
            What Voltages do you get on the 13.2V pins if you do not have the power supply board connected to the main board.
            • vikivng
              • Feb 2019
              • 228
              HI ,
              WITH power disconnected from mainboard
              DIMM PIN is now 3.7v
              13.2 pins both constantly fluctuate between 3.4-5.7v
              thnx
              • vikivng
                • Feb 2019
                • 228
                ok I can see these pics wll not be good enough to scrutinze.
                Sorry.
                I will upload more i n the morning with my slr.
                  Originally posted by vikivng
                  HI ,
                  thnx
                  OK, looks to be something in power supply problem at this point.
                  Disconnect the LED connector and see what will happen to the 13.2V pins.
                  BTW, I also expect the DIM pin Voltage to be unstable also since the 13.2V is not steady.
                  Inspect the solder joints of the power supply board real well to see if it has bad/cold solder joints or not.
                    • 12276
                    • U.S.
                    Also check all your diodes.
                    • vikivng
                      • Feb 2019
                      • 228
                      so I tested all the diodes and checked the joints..
                      The joints of what seem to be the coils have some black oily like residue ..Not sure if this normal or not.
                      No change in voltages.
                      Could the capacitors be the cause.?
                      How would I check the voltage of the main filter cap?
                        • 12276
                        • U.S.
                        Set meter to 200 vdc, negative probe on negative leg positive on positive leg, BE VERY CAREFUL not to touch that area with your hand, this is the HOT/DEADLY side of the board, check it in standby, then check it after you power up the tv.
                        • vikivng
                          • Feb 2019
                          • 228
                          Thnx.
                          so I had to set meter at 1000 to get any reading which was 330v.
                          Wout that be normal?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Have the components in the red boxes had their pins cut. One of the connections does not look right.
                            • vikivng
                              • Feb 2019
                              • 228
                              yes. They were cut and resoldered above the board.
                              Continuity checked.
                              • vikivng
                                • Feb 2019
                                • 228
                                AT this stage,
                                is it definitely the power supply with these voltages.?
                                • vikivng
                                  • Feb 2019
                                  • 228
                                  Hi guys
                                  im guessing cutting and resoldering above the board is bad practice.?
                                  • mcplslg123
                                    Dell 7506 2-in-1 laptop-no ac adapter issue
                                    by mcplslg123
                                    MODEL:ELL 7506 2-IN-1
                                    M/B: HELLCAT 14 MS TGL 8L (19860-1)
                                    PROBLEM: NO AC ADAPTER
                                    The unit works fine with adapter but gives this message. The adapter is genuine dell 65W(tested ok). PS_ID is working correctly and reaches SIO.R4305 is correct at 33.3 ohms.
                                    PU4301 gate is correct at 3.3V as well as PU4415 gate voltage at 1.8V is correct. 19V reaches PR4401(CLR).
                                    Charging IC is ISL9538C
                                    01 Resistance between CSIP/CSIN is about 2.2 ohms(PR4422/4423 is of correct value)
                                    02.Resistance between CSOP/CSON is also correct at 2.4 ohms (PR4424-25 is...
                                    11-18-2024, 11:34 PM
                                  • ianpoultonknights
                                    Zenbook Flip 15 UX562AI schematic
                                    by ianpoultonknights
                                    Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                    06-26-2025, 02:41 PM
                                  • nerdmafia
                                    Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                                    by nerdmafia
                                    Hi first question posting here, but no need to go easy on me!
                                    I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                                    05-21-2025, 09:39 AM
                                  • atunguyd
                                    Acer x163w Monitor PSU schematic
                                    by atunguyd
                                    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                    03-05-2025, 02:08 PM
                                  • Victor Moreira Silva
                                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                    by Victor Moreira Silva
                                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                    Well, my decice specs are the following:
                                    Model: Acer Nitro 5 AN517-54-55T5
                                    CPU: Intel Core i5-11400H
                                    GPU: NVIDIA GeForce GTX 1650
                                    Motherboard: GH51G LA-L181P Rev:1c
                                    The symptom:
                                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                    05-26-2025, 10:49 AM
