Toshiba Tv Service Is Not Running
  • Hair-design2015
    • Oct 2019
    • 3
    • Northern Ireland
    Hello, I've a Toshiba led Tv/combi model number 32dl833b. The problem is after a while when I change channel I just get the message "service is not running". Only way to get the channels back is to turn the Tv off and back on again. The Tv has a vestel main board 17MB60-3.1 with screen LC320EXN(SD)(A2). I thought it maybe a firmware issue so bought the firmware off ohms but when I try to update the Tv I get the message software update failed. It doesn't even try to update. I can't get the exact replacement board and was wondering what your thoughts are that I could try next. Thanks
    • 12202
    • U.S.
    Re: Toshiba Tv Service Is Not Running
    There's this, closest I see is 32DL933B and 32DL133B, I would contact them and ask if one of these will work, sometimes they will, you might have the right firmware that you bought, make sure you follow the update procedure just as instructed: http://www.toshiba-om.net/firmware.php
      • 12202
      • U.S.
      Might need to start from this page if that other one isn't working: http://www.toshiba-om.net/
        • 12202
        • U.S.
        Got to this page for the 32DL933B: http://www.dl.toshiba.com/dtv/NA/GB/EN/32DL933B.html
        • Hair-design2015
          • Oct 2019
          • 3
          • Northern Ireland
          Thanks for the help, I'll try and find out if another model number uses the same firmware.
          • DarrenHD
            Firmware for older Toshiba TV 22CV100U
            by DarrenHD
            HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
            I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
            https://support.dynabook.com/support...tentId=2865076
            Thanks!
            06-16-2025, 11:56 AM
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
            09-06-2024, 05:27 AM
          • Chrissygizmo
            Toshiba 40l3455db firmware update needed
            by Chrissygizmo
            Hi I've got a Toshiba 40l3455db that isn't powering up, when turning on the screen quickly flashes then standby led flashes red/green constantly.. I've googled this and I believe it's a firmware issue..
            I've tried updating the firmware using a USB stick but I've had no luck as of yet. If anyone could maybe send me a link for the correct firmware update needed I would be really grateful....
            ��Thanks I advance��...
            08-01-2021, 09:55 PM
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
