Samsung UE40F6320AK on / off boot loop problems
Re: Samsung UE40F6320AK on / off boot loop problems
With power cord unplugged, unplug cable from powerboard to mainboard, plug power cord back into powerboard, backlights should come on and stay on=powerboard selftest if backlights don't come on the problem is in powerboard or backlights which need to be fixed first before messing with mainboard which may be ok or not.Last edited by nomoresonys; 10-16-2019, 06:47 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Hi, Ive already unplugged main board and the backlights dont stay on, still just clicks and comes on for a second, then immediately off again, and repeats over and over.
Even if nothing at all is plugged into the powerboard, except the mains power cable, it still clicks repeatedly.
Would the whole powerboard need replaced, or just some capacitors etc?
I have read that around the time this TV was produced Samsung were known for fitting undervalued capacitors??Comment
Check all the diodes, could try heating the powerboard a small section at a time with a hairdryer, go over the whole board and those brown caps the little blue ones too, see if the tv tries to turn on or anything changes.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Tested Diodes, all seem fine.
Whilst on diode mode, I touched all the resistors, all beeped, except one, not sure if that means anything? LolComment
Just tried what u said n gently warmed the power board with a heatgun, after a minute or two the TV has come on as normal!!Comment
Hmm, now maybe try narrow down the area heated to when it comes on, thinking its a bad cap, maybe heat the electro caps small section at a time see if it comes on then the blue ceramic. Could test the caps it's hard to know the esr tho without an esr meter.Last edited by nomoresonys; 10-16-2019, 02:26 PM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I would try just heating up the standby power supply section and see especially around those two lytics caps, https://www.badcaps.net/forum/attach...3&d=1571254351Never stop learning
Is that the right picture Bud it's a resistor circled?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
This OP picture? https://www.badcaps.net/forum/attach...3&d=1571254351Never stop learning
Ok, I see, you mean he should start in that area.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I only have a multimeter, and dont know how to test caps with that?Comment
I would try just heating up the standby power supply section and see especially around those two lytics caps, https://www.badcaps.net/forum/attach...3&d=1571254351Comment
That resistor is 82K Ohms, it is for the RC snubber network for that standby power supply section, I just do not understand why people will use diode mode to test resistor.Never stop learning
Wasnt testing them as such, but as I was there testing the diodes, I thought id see what happened if I tried on the resistorsComment
The LED driver/power supply section. If you disconnect the LED connector, will it be in boot loop?Never stop learning
Can I see good clear hi-res of the whole bottom side of your power supply board?Never stop learning
by TakeatrySamsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...2 Photos
by torchzackHi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't... -
by NolesFanHello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...2 Photos
by eigmaHi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
Main board: BN94-07592P / BN97-08922R...1 Photo -
by blaster_Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting... - Loading...
