Samsung UE40F6320AK on / off boot loop problems
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Re: Samsung UE40F6320AK on / off boot loop problems
    Originally posted by dick_barton
    If you disconnect the power supply from the main board and jumper A5V to PWR ON/OFF using a 1K resistor and switch on, does the B5V and B13 supplies come on.
    1k resistors came this morning, no difference to B5V and B13V when jumper A5 to pwr on/off, exact same result with or without resistor.
    Does it matter which way round resistor goes?
      • 12093
      • U.S.
      With power cord unplugged, unplug cable from powerboard to mainboard, plug power cord back into powerboard, backlights should come on and stay on=powerboard selftest if backlights don't come on the problem is in powerboard or backlights which need to be fixed first before messing with mainboard which may be ok or not.
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Hi, Ive already unplugged main board and the backlights dont stay on, still just clicks and comes on for a second, then immediately off again, and repeats over and over.
        Even if nothing at all is plugged into the powerboard, except the mains power cable, it still clicks repeatedly.
        Would the whole powerboard need replaced, or just some capacitors etc?
        I have read that around the time this TV was produced Samsung were known for fitting undervalued capacitors??
          • 12093
          • U.S.
          Check all the diodes, could try heating the powerboard a small section at a time with a hairdryer, go over the whole board and those brown caps the little blue ones too, see if the tv tries to turn on or anything changes.
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Tested Diodes, all seem fine.
            Whilst on diode mode, I touched all the resistors, all beeped, except one, not sure if that means anything? Lol
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              #26
              Just tried what u said n gently warmed the power board with a heatgun, after a minute or two the TV has come on as normal!!
                PS-ON signal.
                So PS-ON is stable? I still think that for the PS-ON to be going and down, the A5V has to be going up and down also because the PS-ON pull-up resistor is connected directly to the A5V as shown in the picture.
                  • 12093
                  • U.S.
                  #28
                  Hmm, now maybe try narrow down the area heated to when it comes on, thinking its a bad cap, maybe heat the electro caps small section at a time see if it comes on then the blue ceramic. Could test the caps it's hard to know the esr tho without an esr meter.
                    I would try just heating up the standby power supply section and see especially around those two lytics caps, https://www.badcaps.net/forum/attach...3&d=1571254351
                      • 12093
                      • U.S.
                      #30
                      Is that the right picture Bud it's a resistor circled?
                        This OP picture? https://www.badcaps.net/forum/attach...3&d=1571254351
                          • 12093
                          • U.S.
                          #32
                          Ok, I see, you mean he should start in that area.
                          • Bloopeta
                            • Jun 2018
                            • 526
                            • United Kingdom
                            #33
                            I only have a multimeter, and dont know how to test caps with that?
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              #34
                              I will try in the morning, as its almost 11pm in UK
                                That resistor is 82K Ohms, it is for the RC snubber network for that standby power supply section, I just do not understand why people will use diode mode to test resistor.
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  • United Kingdom
                                  #36
                                  Wasnt testing them as such, but as I was there testing the diodes, I thought id see what happened if I tried on the resistors
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    #37
                                    It would appear, that heating this section is what allows it to start
                                      The LED driver/power supply section. If you disconnect the LED connector, will it be in boot loop?
                                      • Bloopeta
                                        • Jun 2018
                                        • 526
                                        • United Kingdom
                                        #39
                                        Yes, still loops with LED feed plug disconnected
                                          Can I see good clear hi-res of the whole bottom side of your power supply board?
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • blaster_
                                            Samsung UE49MU6105K - boot loop, horizontal lines
                                            by blaster_
                                            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                            06-22-2022, 05:19 PM
