Vestel 17PW01-4 PS board stuck in standby
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    #61
    Re: Vestel 17PW01-4 PS board stuck in standby
    It's a 1uF 63v but assume it'll be ok.
    No change.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      #62
      IC500 FAN7711
      1 - VDD 14.93v
      2 - RT 0.001v
      3 - CPH 0.001v
      4 - GND
      5 - LO 0.542v
      6 - VS 13.18v
      7 - HO 13.57v
      8 - VB 14.91v
      The data sheet for FAN7711 says that normal operation is when CPH voltage reaches 7V.
      After changing the capacitor are the FAN7711 voltages as you gave earlier shown above.
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        #63
        I'm away now till tomorrow PM. Many thanks so far..
        But before I go:
        IC500 FAN7711
        1 - VDD 14.73v
        2 - RT 1.762v
        3 - CPH 1.3531v
        4 - GND
        5 - LO 0.000v
        6 - VS 13.66v
        7 - HO 13.67v
        8 - VB 14.93v
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          #64
          I'm back now. I feel like we have given this power supply a good effort and it's probably now the time to throw in the towel.. Are we agreed?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            #65
            Can you change IC806 (FAN7711) as the last resort to rule it out as being faulty?
            With the diode in backwards then the 12V supply would have appeared to be almost a short circuit.
            You've ruled out the two mosfets as being damaged and the supply voltages for the FAN7711 looks good but it cannot be operating since you are not seeing the 12V on the secondary side of the transformer it's driving.
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              #66
              I don't have a FAN7711 in stock.
              It's not stocked by CPC/Farnell and RS have it but as a SMD.
              There's one on eBay for £3.09 delivered which seems a bit steep but It might be worth a punt.
              Now ordered.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #67
                Good luck. Can't thnk of any more moves. Keep that smd capacitor (11.19uF) in case it needs to go back in. What was it's ESR
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  #68
                  The C928 cap measured 9.1uF, ESR 0.00
                  I'll report back when the chip turns up.
                  • Nevillet
                    • Sep 2019
                    • 272
                    • United Kingdom
                    #69
                    The new FAN7711 arrived and replaced the original but unfortunately no changes were seen.
                      • 12192
                      • U.S.
                      #70
                      Originally posted by Nevillet
                      I think we crossed posts..
                      D909 was backwards??? I can't quite understand that because to test them I cut one leg rather than desolder the whole diode..
                      Anyway, it's now round the correct way. Out of circuit the drop was 0.135. (the same as the other 2)
                      Voltage across C970 is 0.000v
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #71
                        That's a pity. Hopefully someone else can offer further assistance and spot what I have missed.
                        • Nevillet
                          • Sep 2019
                          • 272
                          • United Kingdom
                          #72
                          With your help, I've learnt a lot about this board and power supply boards in general. This particular TV had a negative outcome but I'm not overly disappointed. I'll salvage the boards and bin the rest. Sincere thanks.
                          • duwane
                            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                            by duwane
                            Hi All.
                            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                            10-17-2023, 07:48 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • mferna14
                            Apple 820-01958-A logic board stuck on 5V .19amp
                            by mferna14
                            Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                            02-21-2025, 03:42 PM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
