Vestel 17PW01-4 PS board stuck in standby
  • Nevillet
    • Sep 2019
    • 272
    #41
    Re: Vestel 17PW01-4 PS board stuck in standby
    I think we crossed posts..
    D909 was backwards??? I can't quite understand that because to test them I cut one leg rather than desolder the whole diode..
    Anyway, it's now round the correct way. Out of circuit the drop was 0.135. (the same as the other 2)
    Voltage across C970 is 0.000v
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      Originally posted by Nevillet
      0.00v
      see above edited post
      • Nevillet
        • Sep 2019
        • 272
        #43
        The dc voltage on the anode side of D908-9-10 is 0.123v
        I have some new UF5402's in stock. Is there any benefit to swapping them?
        IC500 FAN7711
        1 - VDD 14.93v
        2 - RT 0.001v
        3 - CPH 0.001v
        4 - GND
        5 - LO 0.542v
        6 - VS 13.18v
        7 - HO 13.57v
        8 - VB 14.91v
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          #44
          Have you since tried to power up the set with power supply and mainboard reconnected?
          • Nevillet
            • Sep 2019
            • 272
            #45
            No. I will and report back.
            Same as before: The front of the set blue LED lights and the buttons on the front of the set cause a bleep to be emitted from the logic board with each button press.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #46
              I'm at a loss here. With the power to the set off what's the resistance reading across the two legs of C851.
              • Nevillet
                • Sep 2019
                • 272
                #47
                After charging it reads 375 ohms.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #48
                  So no short problem on the 12V line.
                  Can you initially visually check both Q813 & Q814 for any damage which I think are under the heatsink. There is a possibility that they may have been damaged due to the diode in the secondary circuit being backwards.
                  • Nevillet
                    • Sep 2019
                    • 272
                    #49
                    I've desoldered the heatsink and both mosfets.
                    In off state I have o/c between D & S
                    In on state I have continuity between D & S
                    I've compared the results to a new n-mosfet and the results are the same.
                    I have a very cheap eBay component tester & here are it's results:
                    Q813
                    Vt3.4v
                    Cg3.00nF
                    RDS0.7 ohm
                    Vf 565mV
                    Q814
                    Vt3.4v
                    Cg3.06nF
                    RDS0.5 ohm
                    Vf 564mV
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #50
                      What are the part numbers on the mosfets.?
                      The set should not be powered up when taking the measurements. If they are MTP6N60E mosfets then with your meter set to diode mode there should be a reading one way but not when you reverse the meter leads since those devices have a diode between Drain and Source.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #51
                        So the mosfets check out OK. At this point I cannot think of what else to check out next.
                        • Nevillet
                          • Sep 2019
                          • 272
                          #52
                          The part numbers on both are:
                          1K28AB
                          FQPF
                          13N50C
                          With - lead on the Source and + lead on the Drain i'm reading OL on the Fluke
                          With +lead on the Source and - lead on the Drain i'm reading 0.515V drop on the Fluke
                          This is the same on both.
                          • Nevillet
                            • Sep 2019
                            • 272
                            #53
                            Time to pull the plug me thinks..
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #54
                              IC500 FAN7711
                              1 - VDD 14.93v
                              2 - RT 0.001v
                              3 - CPH 0.001v
                              4 - GND
                              5 - LO 0.542v
                              6 - VS 13.18v
                              7 - HO 13.57v
                              8 - VB 14.91v
                              Check C928, 1uF 25V
                              • Nevillet
                                • Sep 2019
                                • 272
                                #55
                                One last thought:
                                When the owner brought the tv round they reported that the set came on for a few seconds then went into standby. I confirmed this behaviour.
                                When I opened the back I spotted and replaced C851, C969 & C970 which were bulging and had very high ESR readings.
                                From that point forward the set has not come out of standby.
                                • Nevillet
                                  • Sep 2019
                                  • 272
                                  #56
                                  C928 is a SMD, measuring in circuit gives spurious results. Shall I desolder to measure?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #57
                                    Make a note of which way around it is soldered in and be careful not to lose it.
                                    • Nevillet
                                      • Sep 2019
                                      • 272
                                      #58
                                      Its measures 11.19uF. The schm states 1uF..
                                      I've marked it but is doesn't appear polarised.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        #59
                                        One last thought:
                                        And you would have thought that replacing the bulging caps would have resolve the problem and often would have. Unfortuanely it appears to be more than that.
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #60
                                          As a quick test do you have an 1uF, 25V electrolytic cap you could put in it's place. Negative of cap to ground and positive connects to pin 3.
                                          • duwane
                                            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                            by duwane
                                            Hi All.
                                            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                            10-17-2023, 07:48 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • mferna14
                                            Apple 820-01958-A logic board stuck on 5V .19amp
                                            by mferna14
                                            Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                                            02-21-2025, 03:42 PM
                                          • hazi12
                                            Vestel main board 17MB140TC
                                            by hazi12
                                            Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                            Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                            I can send a dump....
                                            10-01-2025, 01:28 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
