tv led kennex DLE-385M8 TP.SIS231.P83 loop
  • poweron
    • May 2019
    • 365
    • italy
    this tvc turns on, the kennex logo appears then turns off, turns on again the logo appears then turns off, for several times in a loop, you can find the firmware to flash?
    thanks
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
  • gabrielA7
    HP 15s-FQ Series / MB: DA0P5HMB8J0 REV: J / Loop turns on and off without video.
    by gabrielA7
    When I turn it on, the white LED flashes and then turns off, and it stays like this.
    We have 3 and 5V S5 as soon as I start it, then the voltages drop because we don't have the MAIN_ON that originates from IT5570 pin 33.
    We don't have a short in the sources.
    I re-recorded 2 BIOSes here on the site, which apparently are OK.
    Now I would go for the EC IT5570 BIOS, but I couldn't find it anywhere.
    What else could I check to make this MAIN_ON pulse appear?​
    04-10-2025, 01:29 PM
  • taslan
    Surface 7 Pro wont boot, shows Logo and immediately turns off
    by taslan
    as stated in the title, my surface 7 pro wont boot anymore.
    When i press the power button it shows the square windows logo for a second and immediately turtns off again.
    I dont even have a chance to get into bios or boot from usb.
    While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
    I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
    Bought it directly from microsoft and used it now and then and only...
    01-16-2025, 01:25 AM
