Backlight and Sound But No Video on Vizio P502UI-B1E
    Hey everyone.
    Found this TV on the side of the road and the guy who put it there said one day it just stopped turning on.
    I took it back and determined that I need to replace the power supply board. Did that and the TV turned on and I could hear audio from my source, but no video and no backlight.
    I replaced the EEPROM but that didn't fix anything.
    Found https://www.badcaps.net/forum/showpo...&postcount=136 and tried throwing it in the oven.
    This fixed the backlight, but still got no picture.
    After that, I tried replacing the T-Con board, but that didn't help either.
    I've been looking and can't find a main board (XECB0TK004060X) for a decent price. Is there anything else I can try or am I out of luck on this one?
    Re: Backlight and Sound But No Video on Vizio P502UI-B1E
    Looked and I didn't see an edit button....
    It's not possible to use a different model number main board is it? I see ones that look the same with slightly different model numbers all over eBay and they're very tempting
      Your Post Header says Backlight and sound but no video. Then inside the Post you say you hear audio from my source, but no video and no backlight. Are your Backlights working? If YES then your problem lies in a shorted capacitor on the Panel Bd. ( the long boards attached to the LCD Screen). If NO then the LED Driver in the PSU if at fault.
        Have a look at shopjimmy's website and see if they suggest suitable replacement boards
          So are you getting the backlights or not?
          Please upload good clear pictures of the whole back side of the TV showing all the boards.
            Sorry, I was going step by step with what I did and what it fixed.
            I didn't have backlight at first, but it came back after throwing it in the oven.
              Just went to go take the pictures and now the backlight isn't turning on again -.-
              Pictures are here: https://photos.app.goo.gl/zek6Zbn4gaWfQWJN6
                Another update: Backlight is working again. Didn't change anything besides putting two screws in the main before putting it away for the time being
                  Since now you do have baklights, so what do you see on the screen if you have the ribbon cables between the T-CON and the LCD panel connected one at a time?
                  BTW, make sure to put all the screws for the boards back in place.
                    I don't know what's going on with the backlight. Sometimes it turns on, other times it doesn't. When it does turn on, it'll stay on indefinitely. But if I turn the TV off and back on, the backlight might not turn on again.
                    When it does work, this is all I see on the screen regardless of what's plugged into the TCON:
                      "When it does work, this is all I see on the screen regardless of what's plugged into the TCON:" What do you mean by " regardless of what's plugged into the TCON"????
                        When leaving both disconnected, I see what is shown in the picture. When I have the left ribbon cable attached, I see the same thing. If I disconnect the left cable and attach the right, I see the same thing.
                          Any ideas?
                            "When leaving both disconnected, I see what is shown in the picture."
                            So you are saying you are see grey screen with minus symbol in side the circle when no cables from T-con to LCD panel connected?
                            I cannot see how it will have ANY image on the screen at all when the panel is not even connected to the T-CON board.
                            That is the screen shot of your panel, correct?
