Seiki SE32HY27 - No backlight on 2 system boards
  • wyrmzr72
    • Oct 2019
    • 8
    Hello all,
    I'm working on a Seiki SE32HY27 LED TV. It was most likely the victim of a power surge, at which point I had the user unplug it, and it went from no power to power with no back lights.
    I replaced the board, since this unit has the main and power board integrated into one unit, and the first replacement gave me no power, just a red indicator light. So, I exchanged that for another, which is back to powering on, but still no back lights.
    I'm getting a reading of 48 volts from the LED power when the TV is on, and 41 volts when it's off. This unit has 3 strips of 8 LEDs, and from what I've seen, a typical white LED needs somewhere around 3.3v to power on, which would give me 26.4 volts per strip, if my math is right.
    Right now I'm leaning toward trying to test each strip, but assuming that 48 volts for one strip would be too much. I'm debating digging up an old laptop power supply to test each strip, hoping that one strip has become shorted. Since the laptop power supply is rated 19.6 volts (at least, most of the newer ones I've seen are), is this going to be enough to power a whole strip?
    Quick edit: I tested the individual strips for resistance, and every one of them reads infinite. While I find it hard to believe all 3 strips would typically go out at once, I set my meter to 20M ohms and still get the same reading, so I'm thinking the entire set of strips is bad?
  • wyrmzr72
    • Oct 2019
    • 8
    Re: Seiki SE32HY27 - No backlight on 2 system boards
    And just for the record, these LED strips are not what I'm used to seeing; the back of the strip appears to ground to the TV itself, and if those small solder joints are test points, they're not working with a 3v power supply.
    There are no solder joints on the back of the strips; just one solid piece of copper, with the occasional hole for a screw, or what may be some kind of "test point", which would actually just ground the strip to the back of the TV.
    • cheeky2
      • Dec 2012
      • 336
      I would suggest you read up about how to test leds as resistance of the led strips has no bearing as to the condition of the leds. If you do your homework then you will have your answer. Everything to find your answer is on the forum ie test the leds voltage with reference to the chassis ground of the TV and not across the two connections on the leds. No grounds are on the back of the strips that connect to the leds, it might have a copper strip on the back of the leds. Scratch the white paint off the front to test individually the leds.
      • wyrmzr72
        • Oct 2019
        • 8
        Thanks for that info. I was assuming that if power was supposed to go through the strips, then I'd have some continuity.
        I'll try my 3v test and see if I get anything from scratching the paint off the painted wires. I did search the forums, and saw some people had luck with laptop power supplies, but knowing that 3v x 8 LEDs = 24v (probably slightly higher), I'm looking right now to see if I have a 24 or even 48v power supply (48v should let me test 2 strips at once, I'd think).
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          When you power on does the led voltage jump initially to a high voltage and then drop just as quickly. If it does then this is normally indicative of led(s) problem. If your meter has min/max function then use that function to carry out the check.
            https://www.badcaps.net/forum/attach...1&d=1570299612
            1) Put all the connectors back in place.
            2) Put the meter in DC mode 200VDC scale the attache the meter probes to each leg for the 47UF 160V CapXon cap, then turn the TV on while watching the meter, it should jumps to around 100VDC.
            3) Remove LED connector and repeat step 2.
            BTW, the L2 inductor is broken.
            • wyrmzr72
              • Oct 2019
              • 8
              OK, I tested the voltage across the cap, and it does jump to around 100v with or without the LEDs connected, and then drops right back down to the 48v range. So, looks like I've got some bad LEDs.
              I am testing individual lights now after scraping paint off the circuits, and it appears the first strip has at least 2 bad LEDs. I'll continue checking the rest to see what I come up with.
              Thanks for the help; it appears my search-fu just wasn't strong enough.
                You may want to look into replacement strips and replace them as a set, once it is done then you need to turn down the backlights (not brightness) on all input to as low as possible to extend the life of the LED's.
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
                • edugimeno
                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                  by edugimeno
                  Hi There!
                  I'm trying to help my friend who owns a restaurant be just bought.
                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                  09-05-2024, 09:34 AM
                • sorrowfulfloyd
                  Samsung UE32J5373AS Weird LED Problem
                  by sorrowfulfloyd
                  Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                  This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                  12-23-2022, 07:00 AM
                • adelage
                  220v Led strip flickering
                  by adelage
                  Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                  I know that the best solution would be to get a voltage...
                  11-03-2024, 09:49 AM
