LG TV sound no picture, boards replaced
  • voltman
    • Sep 2019
    • 29
    Re: LG TV sound no picture, boards replaced
    The black soot seems to have originated at the center, and possibly the upper right corner (look at the soot deposit on that blue component) of the power board, even though there are not any visible signs of bad components. The capacitors all "look" good. The center of the power board shows soot and also at the center of the back of the power board. This is all black soot which easily wipes away. The main board is clean. The front LED area was absolutely clean, not a smudge.
    • neilc6
      • Nov 2015
      • 1550
      You can get black soot on boards if the tv is in a home with a heavy smoker.
      • voltman
        • Sep 2019
        • 29
        No smokers in house. Sent you a IM
          • 12206
          • U.S.
          #44
          You got a new power board right? so get the strips and see if that does it.
          • voltman
            • Sep 2019
            • 29
            Can you guys give me a recommended setting for the backlight? It seems factory setting is 90. I disabled auto picture and energy saver and got the backlight at 75 right now. Trying to avoid typical LG LED early death.
            With the backlight setting turned down, is it really necessary to update the firmware? I do not use the TV with internet. Only other function I use is DVD / Blueray. Thank you for your help.
              • 12206
              • U.S.
              #46
              As low as you can stand it, I have mine on 5, it goes up to 20, you don't have to update, a lot of people only update if they are having a problem that might be fixed by it, plus some updates can be buggy so I try not to update at least til the update's been out for a while and there's no bad feedback from users.
                Are you adjusting the BACKLIGHTS level or the Brightness level? My LG TV's BACKLIGHTS are 0 ~20, The Brightness is 0 ~ 100.
                • voltman
                  • Sep 2019
                  • 29
                  Thanks nomoresonys. There is a part of the update called:3. Release History
                  [03.50.50]
                  1. Improve the backlight turn-on failure
                  Since the problem with this set was the LED's burned out (the power board also burned up) I thought maybe there was something in this update other then turning the backlight down, that might prevent premature LED failure.
                  Budm I am adjusting "Backlights". My settings go 0 -100 The factory default setting was 90. I got the brightness on factory setting of 50.
                  My settings now:
                  Backlight 75
                  Contrast 87
                  Brightness 50
                  Sharpness 26
                  Color 60
                  Tint 0
                  TV viewed mostly in artificial light
                  • neilc6
                    • Nov 2015
                    • 1550
                    I believe the firmware updates set the the tv defaults to ECO mode with 70 backlight level. Apps may still run at 100% backlight in Standard mode (access through quick menu). I would run the tv at 60 backlight max. Samsung levels are between 1-20.
                    • voltman
                      • Sep 2019
                      • 29
                      I found out like neilc6 said, when I run the photo/capture app. the backlight reverts back to the 90 default setting. I use this app to view pics and occasional home movies on a USB drive. When I use this app, I solve the problem by putting it on energy saver . My energy saver has 3 settings, “min”, “med”, and “maximum”. I put it on “minimum”. The backlight setting number does not work on the energy setting, but I estimate it to be about 60 on minimum. When I shut the energy saver off, it reverts back to my user settings. This is easy enough to live with.
                      One thing, when testing the power board at the two LED outputs, with the LED's disconnected, I used two different multimeters. The cheap craftsman was not fast enough to read the peak voltage before the board would shut down. All the readings I got were inconsistent and varied a lot. I used an older Fluke multimeter and it would read 25VDC before shutting down. The specs are Minimum 51.4 VDC at each channel. The Fluke was also inconsistent and varied. I don't know if 3 of the LED's blowed and caused the power board to burn up or the other way around.
                      Many thanks to Badcaps forum, budm, nomoresonys, neilc6 and everyone here who took the time to help me. I was able to fix my TV and learned something while doing it. I hope this thread might help others with the same or similar problem.
                        • 12206
                        • U.S.
                        #51
                        Another one saved, nice work.
                        • heathloder
                          IT Enthusiast
                          • Mar 2014
                          • 45
                          Just came across one of these today (LG 43UJ6200) whose backlight was turning off immediately upon power on (flashlight test revealed it was the backlight and not the whole display).
                          LED tester revealed open on LED string number 2. Opened chassis - LED tester found one bad strip (2nd strip from the top on the "right" if you are looking at the LED's from the front). Checked each LED - only one LED was found to be open Literally ONE LED preventing this beautiful set from booting.
                          Just wanted to report here that another one of these models started exhibiting these same symptoms, and turned out to have an LED issue.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • stylishconsultant
                            un60j620dafxza - Samsung No Display Problem
                            by stylishconsultant
                            Hi All,
                            Need help.
                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                            09-04-2024, 03:26 AM
                          • Sgj24
                            55" TCL 55us57-wtlaa TV - No picture, backlight/sound work, T-Con board was replaced
                            by Sgj24
                            Hello all, I was given a 55" 2017 TCL Roku TV that has an issue of no picture, but the backlights and audio are in full operation. I did some digging and narrowed it down to a possibly bad T-Con board, I replaced it today with a unit I got off of Ebay but the issue is still there. I'm not good with electronic testing (multimeter, soldering, etc.) so I would appreciate any insight on the likely cause. Screen appears undamaged and the remote can still switch around settings (I've tried a hard reset). I assume it could be the video or power boards, but I also had a theory on it being the ribbon...
                            09-10-2021, 01:40 PM
                          • ermals
                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                            by ermals
                            Hi all!
                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                            3. I've checked voltages...
                            08-01-2022, 10:35 AM
