soldering ic
  • pete g
    • Jan 2010
    • 20
    soldering ic
    hi all, on some ic's there is a heat sink on the bottom that is soldered to the board. my question is, can I just apply heat sink compound to the bottom of the ic instead of soldering it?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8692
    Re: soldering ic
    Depends, but very likely you're not going to get as good thermal conductance especially when you can't clamp it plus any residual solder is going to add to the resistance due to imperfections... Best to solder.
    • diif
      • Feb 2014
      • 6978
      • England
      Re: soldering ic
      The bottom of some ICs is ground so needs to be soldered.
      • pete g
        • Jan 2010
        • 20
        Re: soldering ic
        o.k. thanks a bunch, guys.
          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
          Securing a good thermal interface between...
          10-07-2024, 04:35 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • valvashon
          Repair Success! Middle Atlantic UPS2200R-IP
          by valvashon
          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
          02-06-2024, 12:54 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • badcapped
          Compaq CQ71 PQ 48 help needed, please.
          by badcapped
          Hello
          I do not do many motherboards and I was asked if I can something to repair it.
          So, I said yes (kind of forced!).
          I started checking PW from plug ... then found there was no 3v3 on PW switch.
          Then I checked various mos-fets as I did not have schematic - which then found here - thanks.
          Not finding anything work - LED on Vin is not pulled down, I then finishes taking motherboard off the laptop and checked other side and found PQ48 practically shorted and getting slightly warmer.
          I also checked it visually...
          12-06-2021, 07:51 AM
