LG 49UH6090 back cover removal.
  • vikingTv
    • Sep 2019
    • 14
    • usa
    Hi all, so I'm a pretty handy guy in general and love to tinker/fix things. I've done so with a few tv's so far and re-purposed them to family members.
    My latest is I have an LG 49UH6090, the backlights have turned blue and slowly getting darker. From some reading I've done the indications are that I need to replace the backlights. That doesn't look too daunting to me and I have the backlights to install.
    Then I tried to take the back cover off this thing. I have every screw out (and feet) and it damn near feels like I'm going to break the back panel in order to get it off. I can't find a service manual anywhere on this. So my question to the collective is how do I get this back cover off. Are there hidden clips along the sides? If so how do I disengage them (i've tried some gentle prying to no avail).
    I've attached an image of the back, the yellow spots indicate screws I removed (legs are off when I try to remove just on for the picture ) I have scoured the tv for screws and can't find any others..
  • Diah
    • Feb 2013
    • 6357
    Re: LG 49UH6090 back cover removal.
    LOL..i can see from the photo how much you pull the cover from left and right and it stick at the middle.. how about the 4 white clips round LG logo on the cover for wall mounting !!
      • 12129
      • U.S.
      Some are taped down pretty good, they use a plastic spudger tool, make sure you didn't miss any screws in the power plug and mainboard area.
      • vikingTv
        • Sep 2019
        • 14
        • usa
        so it was a series of clips. I had to pop the first one toward the bottom a bit harder then i liked using a small flat head screw driver. After i did that the rest you can get.
        There are a series of them running up the side. I was just afraid I'd damage it as it took a bit more force then I like to use on electronics. But no damage yet.
        That'll come later...
        I'll take a pic of the clips just in case someone else runs into this.
          Yep, you have to open from the bottom edge and then work your way around.
          https://www.badcaps.net/forum/showth...738#post915738
          • vikingTv
            • Sep 2019
            • 14
            • usa
            thx Budm.
            I think it was one of those things where I knew it had to be a clip, but was worried it was some other trick and I was gonna break something as I did have to use a bit more force then I like.
            That said, of course I get my panel apart and the LED strips I have are not the right ones. Guy told me if they weren't the correct ones he'd let me return them, they came out of the same model tv, but my strips have 8 LED's in a joined A/B stip, the ones I got from him have 9. oh well off to track down some other ones.
              When you try to get the replacement LED strips, you should make sure that they are made for the LCD panel model number since same TV model may not use the same LCD panel.
              • vikingTv
                • Sep 2019
                • 14
                • usa
                You are of course correct. I happened upon a good deal, didn't have time to tear the TV apart to verify the part. and I asked the guy and he said he'd take em back if they were incorrect. Just stinks that i have a torn apart TV and have to wait on new strips. but is what it is.
                as an side, I can't believe it took me this long to find this forum. I have many more questions coming
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • mrdevil
                  Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                  by mrdevil
                  Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                  However, after about 12 months, I had a number of these stop working...
                  01-08-2025, 03:19 AM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • NolesFan
                  sony kd-85x85j Looking for info on how to remove back cover
                  by NolesFan
                  Like the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
                  03-14-2025, 08:23 PM
                  by momaka
                  03-15-2023, 10:17 PM
