Samsung PS51F4500
  • satinser
    • Oct 2012
    • 214
    Samsung PS51F4500
    Customer reported sound with no picture.
    Suspected from description of fault Ysus display board at fault.
    With this model buffer chips built in to Ysus.
    Xsus built into power board.
    Mainboard with built in logik.
    Total number of board therefore been kept down to 3.
    All voltages test as correct on panel sticker but absolutely no picture or brightness from the screen or flash of screen when first switched on.
    There is a sound however coming from behind the screen i can liken it to the noise some CRT tvs would produce when displaying a high contrast scene. The mainboard has green led flashing 1blink then 3 seconds off and repeating. Does anybody know whether this is the sign of normal operation as i have no service manual?
    Because all voltages are reading good but still no screen activity of any kind thoroughly checked the screen for damage or any damaged burnt pixels.
    There is small chip about the size of a pinhead on the screen barely discernible its difficult to see whether this has compromised the seal of front glass layer of screen.
    Its difficult to believe but could this be the reason?
    I dont have the service manual and neither can i find one from usual sources.
    Any advice from anybody in the know appreciated.
  • R_J
    • 9535
    Re: Samsung PS51F4500
    I have seen cracks in a plasma screen that still worked and I have seen screens with a chip that did not work, If the gas escaped, it is done. If you feed video to the tv does the sound seem to come from the whole panel and does it sem to change with the video signal? if it does I would suspect the panel. You could also scope the signal going to the buffers and the panel. (10x probe as the signal is large)
    • satinser
      • Oct 2012
      • 214
      Many thanks RJ. Your thoughts and comments very much appreciated.
      Using EMR Diagnostika meter it clearly indicates normal energising of Ysus and Xsus section of power board. The ribbon connectors from both Ysus and xsus are also energised to panel. Despite all this the screen shows absolutely no illumination or activity whatsoever so looking increasingly like loss of gas from pin hole chip has occurred.
      Over the weekend I will connect a working video feed as youve suggested and feedback the results here.
      • satinser
        • Oct 2012
        • 214
        I can confirm that when fed video from set top box to HDMI port audio is as present as always but loud vibrating crackle noise is coming from the front of the screen. Its difficult to pinpoint in which area the noise is coming from. It does indeed alter in intensity and pitch in relation to video levels of input.
        I guess this confirms Panel failure and thanks once again RJ for your reply and suggestions.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
          09-07-2024, 05:50 AM
